08-21-2020, 01:09 PM | #1 |
///M3eeee
Rep 20
2002 e46 M3 Black SMG VF SuperCharged 502 RWHP
After buying a car that is friendlier for a larger family (4 door), I need to sell my beloved e46 M3. I have put in probably $40-$50k in mods and maintenance into the car and it is running amazing! I will try to list all the large ticket items I've done but I'm sure I'll forget some. Please ask if there are any questions and/or if you are interested in buying the car. The car runs and drives great! I’ve made several long-distance trips (>6 hours) with this car and never was concerned about its reliability. The Supercharger is very nice to drive as the power is very linear and pulls the entire powerband, no surprise jump in power like the Turbo kits. The VF kit also makes driving in hot weather better considering it is water-cooled. The car is garage kept and almost exclusively driven in the summer months. Oil changes were done every 3k miles with Castrol TWS 0w-60 and BMW oil filters. I've not driven the car much in the past 2 years because of the new additions to the family but I do need to sell the car. Price: Asking 18.5k OBO. (Reduced from 21k) History: ------------- I bought the car over 9 years ago used with around 128k miles on it. From there I have done an extensive number of mods and maintenance to ensure the car runs forever. Throughout the year's things have gone bad as with any car. I have replaced everything OE or Greater materials when doing maintenance. The car runs amazing and I hate to let this car go but I don’t have room for 4 cars. Stats: -------- 169k Miles 502 RWHP (Dyno) Trans has around 70-80k Miles SMG Pump has around 10-15k Miles VF570 Kit + Custom Tune 20-35k Miles AquaMist Direct Meth Injection Kit 15-30k Miles Mods and Maintenance: -------------------------------- VF Engineering VF570 Supercharger kit (included Injectors, Plugs, etc) – 2013 Custom Tune – Frank Smith in MD Methanol Injection (AquaMist) – Direct Port Injection kit. SMG ECU Flash from ESS - 2013 Dynavin D99 Head unit with Steering controls and OBC integration Valve Cover Gasket - 2018 Yaw Sensor - 2018 Final Stage Resistor - 2015 Rear Subframe Plates Welded + Rust Prevent Painting - 2017 Transmission (Had 60k Miles with Flywheel) - 2017 Transmission Springs - 2017 SMG Pump (Brand New) - 2017 Vanos seals - 2015 AGM Battery - 2017 Valve Adjustment and compression check - 2015 Headers (before I bought the car) - > 2010 Oxygen Sensors and Header Gaskets - 2014 Borla Exhaust System - 2009 Rear Backup Camera with IR for Night time - 2017 Clear Bra - 2010 LED corner lights, LED tail lights - 2012 Projector Fog lights - 2013 Rims and Tires (Silver Rims w/Lip) 19 x 245 and 275s – 2017 D12 Racing Suspension – 2013 Angel Eyes (before I bought the car) - >2010 Window Tint – 2016 ZCP Brake Kit upgrade with SS Lines – 2015 Polyurethane Subframe bushings and Trailing Arm Bushings – 2017 and 2013 Alternator – 2015 Power Steering Pump– 2016 High Flow Fuel Pump (with Super Charger Kit) – 2014 Rear Main Seal – 2017 Stage 2 Clutch – 2017 GIUBO (driveshaft Flex Disc) – 2017 M5 SMG Shift Knob – 2014 Carbon Fiber wrapped Interior Trim – 2012 LED Interior Lights All-Weather Mats Aluminum Paddle Shifters Mikey Mouse Gauge Pods (Boost and Meth Gauge) Starter – 2015 Oil Level/Temp Sensor - 2016 Carbon Fiber Front Splitters – 2013 Car Comes with: ----------------------- Several stock parts (airbox and other parts) SuperCharger Oil and Extra Airfilter Car Cover Lots of paperwork/Records of maintenance/mods. Battery Tender Jr with quick detach Extra and/or Optional cost: ------------------------- Extra set of Rims and Tires – Black ZCP replicas 245 and 275s DISCLAIMERS: -------------------- The car is running catless. Prefer to meet somewhere in Northern VA. Last edited by pish180; 04-08-2022 at 09:53 AM.. Reason: Change in Price |
10-06-2021, 05:43 PM | #6 |
Rep 1,196
Rod bearing service performed? Any subframe issues?
2009 BMW 335i 6MT
*big single (eventually)* For now... MHD tuned VRSF Race IC DCI ATM exhaust |
10-07-2021, 07:43 AM | #7 |
Bored all the time
382
Rep 2,173
Really nice looking e46 M. Good luck!
Current: 2014 991 Turbo RS
Past: 15 GT3, 17 R8 SC, Two 16 M4 GTS’s, Two 18 GT350R's, Two 13 RS5’s, 13 M3, 10 R8, 15 M4, 09 M3, 04 M3, 09 S5, 02 M3... It all started with an RX-7 (FD). |
10-31-2021, 06:04 PM | #8 |
Rep 4
I'd like to talk to you about this car but the AIM is the only way to get you and that's not working.
my email cobradriver@gmail.com Thanks |
10-31-2021, 09:37 PM | #10 |
///M3eeee
Rep 20
Hey bud, honestly the bearings may have been done before I bought the car. I've checked my VIN and it doesn't say I'm delinquent on that. I bought the car with around 120k about 10 year ago. I've been religious on the oil changes at 3k with filters. I've never seen any kind of metallic flakes, cloudly oily or anything that would show signs of failing bearings, so I'm not even remotely concerned.
Yeah subframe was done with plates. It should be in the description. Hope that helps! |
Soden82478.50 |
11-02-2021, 08:49 AM | #11 | |
///M3eeee
Rep 20
03-23-2022, 08:18 AM | #17 |
Bored all the time
382
Rep 2,173
I can't believe this thing is still for sale. What kind of exhaust is on it? I see you mentioned it runs catless (which means headers are aftermarket) but what about the rest?
03-23-2022, 02:18 PM | #18 |
Field Marshal
6729
Rep 1,829
Drives: '08 E92 M3
///M Power-Belgium63418.00 |
04-08-2022, 09:49 AM | #19 | |
///M3eeee
Rep 20
It's catless and it is running a Borla exhaust. Also thanks for bringing that up, I don't have it in the description! Totally forgot about it, since it was one of my first mods (stock was way too raspy for me). |
Tags |
black, bmw m3, e46, for sale, sale, supercharged, virginia |
