      10-22-2020, 06:27 PM   #1
hybrizyme
Drives: 2011 BMW M3
Coolant Temp
I have a 2011 M3 S65 with a DCT code of 2B59 (Coolant Thermostat Monitoring).
It looks as if I need to change the Thermostat. The OBDII ECT (Engine Coolant Temp) is 160 F (71 C). The Thermostat is set point is 79 C (174 F). Seems like the minimum coolant temp should equal the Thermostat activation temp ~175 F.
This code showed up less than 1 year ago and I changed the Thermostat and sensor. It's hard to believe that I need to replace the Thermostat so soon. Can thermostats fail so soon? Could it be something else?
Thanks,
Randy
      10-22-2020, 08:53 PM   #2
pbonsalb
Is your oil temp normal? Does your fan run a lot?
Tags
coolant, ect, temperature, temperature sensor, thermostat, water
