04-28-2013, 01:25 PM | #1 |
Rep 556
spacers
what are ze baist?
Just kidding. I have moved onto an OEM 18x 9.5 ET 23 square set up on 275/35/18. i have been searching this topic. I came across the sticky from rldzhao's thread and read it. searched threads, pics, etc but in some instances some never answered the question of which spacer they are running. i am figuring running the 12mm in front and 15mm in rear. i saw the dude with the blue OEM wheel running 10mm and 15mm, but after reading the 10mm is more of tuner pick and the hubcentric ring figured the 12mm would be a good choice. i am on stock suspension, car is all stock. i do plan on getting a KW S/O or eibach for reduced gap not sure if how much that will affect the set up. thanks in advance Last edited by red998; 04-28-2013 at 02:22 PM.. |
04-28-2013, 02:11 PM | #2 |
Rep 6,734
Classic post... Nobody can help you without knowing the wheel offsets.
'23 X7
04-28-2013, 02:25 PM | #4 | |
General
21115
Rep 20,741
Drives: 2021 911 turbo
However, it is preferable to avoid using wheel spacers at the track. Spacer put much more strain on wheel bolts or studs. It is much better to simply get wheels with the appropriate offset. EDIT: With a 23mm offset, you don't need to use any spacers. Last edited by CanAutM3; 04-28-2013 at 02:31 PM.. |
04-28-2013, 05:43 PM | #5 |
Rep 556
stock is 29, 23, will the additional 6mm offset make a difference? sorry if this has been asked already but i been reading and searching with not much an answer.
04-28-2013, 09:18 PM | #6 | |
Rep 6,734
Rear: No spacers needed but 12mm looks great. Spacers: I agree that spacers aren't ideal but quality spacers installed correctly with the proper length lugs or studs are perfectly safe. Turner Motorsports spacers and studs are my favorites. I'm not a fan of 10mm spacers because you can have issues with the 11mm hub protrusion. I only use 5mm, 12mm, and 15mm spacers. 5mm leaves just enough hub protrusion to insure hub centric (can be an issue for certain wheels), 12mm is thick enough to avoid any possible hub protrusion issues and anything greater than 15mm means you have the wrong wheel offset IMO....
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M Last edited by slicer; 04-29-2013 at 11:53 AM.. |
