  TireRack
      09-24-2014, 03:35 PM   #1
kt35
Drives: e92 m3
OEM 18 Rear Fit
Can I use the front OEM 18 wheels on the rear? Searched the forums and seems like I can but wanted to confirm. Front is 8.5ET29 and rear is 9.5ET23 I wanted to run a square winter setup using the front OEM 18s and 235/40 tires. I realize that in the rear, the wheel will sit in a little but not as concerned about aesthetics as long as it drives/clears everything ok.
In the above setup wouldn't the wheel be more flush than if you used 270M wheels (the bmw winter setup)? They are 18x8ET20.
Thanks
      09-25-2014, 12:43 AM   #2
r53s65e90
8300
r53s65e90's Avatar
Drives: r53 s65e90
Yes. I tried it once out of curiosity. Looks set in but its fine. Clears everything without a problem. I drove around for a while until my street rears were fixed. On the front I had my street fronts and in the rear my track fronts. Both OEM 219 18 fronts.
      09-25-2014, 08:18 AM   #3
Richbot
Drives: Jerez Black E90
Yes with that size it's fine but you will rub the fender liners of you try to run it with the OEM rear tire. Wheel size is fine but the tires are a little too tall.
      09-25-2014, 10:24 AM   #4
kt35
Drives: e92 m3
Thanks. Not going to run the OEM rear tire (265/40). If I go with the square setup like that, I would run 235/40 (for the winter).
Search this Thread:
Advanced Search
