03-17-2015, 01:04 PM | #1 |
Rep 649
GTS Wing double tape/betalink vs screws
Hey guys i was wondering if their is a way i dont have to drill the wing on. Can i use a strong 3m double tape or even a glue like betalink? the only downside is their is not enough surface contact to double tape. I was thinking of maybe expanding the bottom rectangular like part where its mounting holes are to a flat even large square piece. But anyways, im assuming wind will probably lift the 3m tape? what about betalink?
03-17-2015, 01:58 PM | #2 | |
coupe la goon
373
Rep 1,640
Drives: green, black, white
Garage List 2011 BMW 1M Coupe [10.00]
2013 BMW M3 Coupe [10.00] 2010 BMW 535i xDriv ... [0.00] 2008 BMW M3 Coupe ( ... [0.00] |
03-17-2015, 02:36 PM | #3 |
Rep 649
03-17-2015, 02:56 PM | #4 |
Apex Everything!
976
Rep 4,378
Drives: 2007 Honda S2000, 2017 GT350
Not a good idea at all. It will go flying off at high speeds.
03-17-2015, 02:57 PM | #5 |
Rep 4,744
Drives: S65 1M Clone & E92 M3 4.6L
You have to drill the wing it. It will rip off with tape and beta link overtime will crack.
Betalink requires a repaint if you remove the wing. It's not much more work to fill in the drilled holes. |
03-17-2015, 03:05 PM | #6 |
Rep 473
I tried this myself with 3M double sided tape...wing flew off at 60 mph . Not sure how strong betalink would be but I suggest drilling holes due to the wing only having two small contact points. If you don't want to drill into your existing trunk get an aftermarket one.
03-23-2015, 11:25 PM | #8 | |
Rep 6,723
