  TireRack
      02-06-2012, 05:03 PM   #1
MAKAENA
Drives: Looking for a E92
BBS LM fitment - Question
I recently picked up a E92 and was wondering if I could fit a 20x10 + 15 in the front?
      02-06-2012, 05:08 PM   #2
Mr.MichaelM3
Mr.MichaelM3's Avatar
Drives: 2015 AW F80 M3
AND BY plus 15 you mean with a spacer correct!? I know for the rears you can barley fit a 305 without rubbing and NEED a spacer. I'm not too sure about the front's tho.
      02-06-2012, 05:38 PM   #3
frenchM3dreamer
Drives: 08 Mitsu Eclipse Spyder GTP
+15 means ET 15 (positive offset)...
      02-06-2012, 05:42 PM   #4
GTM_Challenge
GTM_Challenge's Avatar
Drives: E92 M3,X5M,F30 335
Send a message via AIM to GTM_Challenge
The BBS LM is made in 20x10 +20 or 20x10.5 +15
The 20x10 +20 CAN fit but would be very tight. Youll likely need a coilover with camber plates so you can dial in -2.5 camber or more and use a 265 wide tire max, maybe a few 275s may fit....
Ive fit 19x10 +20 with a 5mm spacer in front with a 265 using KW clubsport coilovers. The 5mm spacer is not needed for oem spring/strut, but looks/handles alot better with some camber in front.
      02-06-2012, 05:57 PM   #5
MAKAENA
Thanks for the information Greg!!! Correction.. 20x10 + 20
Search this Thread:
Advanced Search
