10-21-2010, 09:58 PM | #1 |
Moderator
675
Rep 4,737
"Tighten in Normal Position"
I was looking at the torque specifications for the rear suspension arms, and I noticed under many torque values, there is "tighten in normal position".
I believe this means that you have to jack up the particular suspension arm you are working on to lift it into its normal steady state position, and then tighten to the specified torque value. Clarification: see post #22. |
10-22-2010, 07:42 AM | #3 |
Rep 7,887
10-22-2010, 08:11 AM | #5 |
Rep 7,887
10-22-2010, 11:08 PM | #6 |
Rep 3,735
This should be normal understood procedure from any competent technician or installer. Doing it any other way is completely wrong.
I would hope most do it this way. Either a ramp, or hydraulic loader from underneath should be used if the car is on a lift with the wheels off the ground. Not doing it this way will cause the car to perform poorly and destroy the bushings much quicker.
BMW PERFORMANCE SPECIALISTS. Race Engines. Suspension. F/I. Brakes. Race Preparation. Factory Service. Alignments.
OFFICIAL PARTNERS: KW. MOTON. Brembo. AP Racing. BBS Motorsport. iND. HRE. Turner Motorsport. VAC. BMW Motorsport. Facebook | Instagram | Yelp! | Flikr Phone: 949-233-0448 | E-Mail: info@mrfengineering.com |
10-23-2010, 07:44 PM | #7 | |
Rep 961
10-24-2010, 12:05 AM | #8 |
chris
278
Rep 12,144
hmm... what kind of work would require the disassembly and re-assembly of these parts? would you need to do this for a coilover install? sorry i am not very knowledgeable when it comes to suspension components.
10-24-2010, 02:44 AM | #9 |
Rep 961
Changing the rear suspension (damper, spring, or both) involves removing the bottom bolt on the damper and the bolt that ties the Camber Link to the Wheel Carrier. Both have to be reinstalled "in normal position". There are no bolts in the front suspension that have to be done this way.
10-24-2010, 01:04 PM | #10 |
chris
278
Rep 12,144
interesting. my coilover install was done at a shop that didnt have a hydraulic platform lift to do work like that. it was hoisted on a regular lift and tightened while there was no load on the suspension components. i've been driving the car with KWs installed for the whole summer. anyone knows what kind of damage could i be facing?
10-24-2010, 05:26 PM | #12 | |
chris
278
Rep 12,144
i've seen people do coilover installs in their own garage and they dont put any load on the suspension when bolting everything together so i didnt think it was much of an issue. but this is nevertheless interesting to take note of.
10-24-2010, 05:48 PM | #13 | |
Rep 7,887
10-24-2010, 10:32 PM | #14 |
Rep 961
I've done my rears a few times now, and here's what I experienced:
First, to align the bolt holes for the 14mm bolt that holds the Camber Link onto the Wheel Carrier, you have to lift the Camber Link up to almost the fully loaded position. Just tighten it then. My opinion is that this instruction only applies to the regular 3-series in any case. On the M3, the connection in question is a ball joint; it's free to rotate, relieving any tension from the bolting process. Second, for the rear damper, KW or OEM, the lower bolt passes through a sleeve locked in a rubber bushing. It needs to be bolted at the appropriate height or the bushing will be twisted at static ride height. As for doing it at home, the rear Camber Link is a breeze to lift with a jack - you just have to remember to do it. |
10-24-2010, 11:21 PM | #15 | |
chris
278
Rep 12,144
10-25-2010, 11:10 AM | #17 |
chris
278
Rep 12,144
thanks, i'll jack the car up and take a look at the bushings when i change to my winter wheels and tires.
10-25-2010, 01:04 PM | #18 | |
Rep 3,735
For the front suspension, this applies to all fellow M3posters who have modified their suspension: -Tighten your top hat bolts (the 3 13mm bolts) with the wheel hub under load. This will ensure trouble free and noise free operation and will not strain the upper hat stud threads. -For the front damper, tighten the center bolt while the system is compressed, it will ensure the bolt fully tightens. If this bolt isn't fully tightened, you may experience noise immediately or eventually down the line. -Anti-roll bar end link.. Suspension must be aligned correctly, then tightened. Do not barely align it and expect the bolt the pull the suspension into its proper position, you must put it there first. -Malek
10-25-2010, 11:29 PM | #19 | |
Rep 961
If you tighten the bolts in the same position as they will be when the car is standing on it's wheels, then they're in the right place, loaded or otherwise. While many purists will argue the only way is to put the tires on and lower the car onto its suspension before tightening, frankly you can measure the position of the hub relative to the fender opening with a tape measure and tighten the bolts while you support the control arm on a hydraulic jack. If you do one side at a time, the car never rises off the lift holding the body when the arm is at the correct height. |
10-25-2010, 11:34 PM | #20 | |
Rep 961
You are correct with respect to the front suspension, although that particular set of cats can be skinned other ways. It's about getting everything firmly in place before tightening. The anti-roll bar end links are ball joints, so they have no rotation orientation to worry about. As for getting all this stuff correctly in place, if someone's doing a DIY and they don't know what "correct" looks like and how to get it all there, they'd best get a pro to do the work. |
10-25-2010, 11:36 PM | #21 |
Moderator
675
Rep 4,737
After much thought I still don't understand why "tighten in normal position" is needed.
My thinking is, most of these joints are just ball joints, which is allowed to rotate about the bolt axis freely. This is what allows it to articulate when installed. The only issue I can think of are the lubrication boots, as they may be strapped to a non-moving part. Please correct me if I am wrong. |
10-25-2010, 11:53 PM | #22 |
Moderator
675
Rep 4,737
I think I finally get it.
For ball joints (left side of each arm in picture below), tightening in normal position probably does not matter because it is free to rotate. But for actual bushings (right side of each arm), tightening in normal position will matter because the rubber will be loaded when not in normal position. When we do a rear spring/shock replacement, the lower camber arm outer joint is a ball joint, that's why it is OK to tighten that joint when NOT in normal position. |
