  TireRack
      03-18-2015, 07:56 PM   #1
beyondM
Drives: 2011 Silverstone II E90 ZCP
Just noticed recently that my tires are rubbing on the backside of the fender lining. It's rubbing both on stock zcp rims with Pirelli p zero 245/35/19 and also my track apex ec7 18x10 with rs3 275/35/18.
The rubbing only happens when I'm turning right. I checked the liner and all the bolts seem to be in place. Drove with the car almost a year with no problems.
It's a minor rubbing but it's annoying as every right turn I hear a bumping clunking sound.
Anybody ever experience this? Or know a solution for this?
      03-18-2015, 07:59 PM   #2
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
Heat a flat piece of curved metal with a heat gun and press. I reshaped my entire inner fender for better clearance.
      03-18-2015, 08:52 PM   #3
beyondM
Let me give this a try this weekend.
      03-18-2015, 09:23 PM   #4
BzsBimmer
BzsBimmer's Avatar
3278
Drives: '23 G80 FO M3, M3 & MY Tezzy's
That's great and all but you're not looking for the root cause.
BMW did not design your car to rub on factory wheels/rubber.
You also mention a bumping clunking sound. I'd get her on a lift and peek up her skirt.
Sounds like something wrong downtown.
      03-18-2015, 09:31 PM   #5
beyondM
Had my friend stand outside while I made a slow turn and the clunking appears to be the tire hitting the fender liner.
Car is out of warranty and not exactly stock by dealer standards. Probably will have a look while on the lift getting my oil change this Friday.
      03-19-2015, 12:14 AM   #6
BzsBimmer
BzsBimmer's Avatar
3278
Are you the first owner
Does the car align well within nominal range or did they have to make a lot of adjustments (possibly from a past accident or suspension hit)
Is the fender liner properly attached
      03-26-2015, 05:33 PM   #7
Lunker325
Drives: E70 X5M / 991.2 C4S
I have this same problem, but running 275's on 19x10 wheels up front. I tried to heat the liner in that area with a heat gun and bend it back, however there is metal structure right behind that spot. The plastic only bends so far. I can live with it though as it only happens when turning at low speed and the wheel passes that spot.
'17 Porsche C4S Sapphire Blue Metallic / Bordeaux Red - Softronic tune - Soul Sport Cats - Soul Exhaust
'13 E70 X5M Black Sapphire Metallic / Bamboo Beige - Full Dinan Suspension - Dinan Exhaust - BPM Sport Tune - xHP Flashtool Transmission Tune
