03-13-2017, 09:07 AM | #1 |
Boost Addict
174
Rep 460
Rod Bearing Choices limited supply, need in a hurry
I have spent hours on here watching people debate theories and which bearing company is better etc etc..
I just supercharged my 08 e93 with a 625 kit and i wont be comfortable pushing it until my bearing are done. Most garages say they cant get the extra clearance bearings in until april most likely may, WTF but others claim VAC is in stock. I've also read that BE has their own variation of ARP bolt ??? is this correct? bore distortion etc.. this shits getting complicated. For guys supercharging please can someone clarify which direction would be the best PROVEN application. Also if anyone can get stock i'd be game to purchase asap.. Also what part numbers should i be looking for ? thanks so much in advance
F80 BMW M3 DCT YMB
2008 BMW E93 6MT, Ess VT2 625 |
03-13-2017, 09:26 AM | #2 |
Rep 10,589
None are proven yet. If you are concerned about your original bearings, and I would be if I was you, I would change them to any of the options. My first choice would be BE/Clevite extra clearance with ARPs, my second choice would be VAC/Clevite with ARPs, my third choice would be OEM/WPC with stock bolts and my fourth choice would be OEM with stock bolts. I use OEM/WPC with stock bolts.
Once you see the condition of your bearings at your mileage, you can determine the next change interval. If I had terrible looking stock bearings at 50k miles, I would not install BE with ARPs and not check again until 200,000 miles. I would be redoing the bearings again before another 50k miles. Hopefully they would look great and I would then be comfortable leaving the next set in longer. Mine were bad at 60k but not about to fail, so I will replace them again at maybe 110-120k and see how the WPC treated ones held up. None are proven yet. Very, very, very few have been removed and replaced again. The person who has removed and replaced the most replacement bearings is Malek at MRF and he uses VAC/Clevite (and before that he used VAC OEM with Calico) and I think he reported that all the VAC bearings he has pulled for a second time have looked good. I am not knocking BE, but far more VAC have been checked than BE at this point in time. Last edited by pbonsalb; 03-13-2017 at 12:24 PM.. |
03-13-2017, 09:32 AM | #3 | |
Boost Addict
174
Rep 460
F80 BMW M3 DCT YMB
03-13-2017, 12:27 PM | #5 |
Rep 10,589
Beware there are a few instances of vac sending stock coated bearings instead of vac/Clevite. Make sure the order is correctly placed and verified upon receipt.
03-13-2017, 09:09 PM | #6 | |
Boost Addict
174
Rep 460
F80 BMW M3 DCT YMB
03-14-2017, 07:45 AM | #8 |
Rep 724
The WPC treated OEM bearings have probably been used more than any other available type. EAS on west coast and Autohaus? On east have install deals on them. WPC seemed to be the preferred solution prior to BE.
When I replaced mine I was in a similar situation, BE's were on back order, I had to find who had WPC's in stock as many on-line sites did not have them available. |
Maxf80M3174.00 |
03-14-2017, 09:42 AM | #9 |
Rep 2,907
Drives: 2011 E93 M3
I've replaced dozens of sets with OEM/WPC, VAC, and BE over the last few years. None of them have come back with any problems that I know of- knock on wood. Now I only use BE as I feel they have the best solution right now.
*putting my flame suit on* I don't think it's quite as important to use one type over another as long as you can verify adequate clearance during installation. IMO it's more important to get in there and do something to address your current bearings before they present issues. |
Maxf80M3174.00 |
03-14-2017, 10:36 AM | #10 | |
Rep 1,017
Drives: 2010 E92 M3 6MT
whats77inaname824.50 Maxf80M3174.00 |
03-14-2017, 11:18 AM | #11 |
Crazy!
1180
Rep 1,440
What you definitely don't want to do is post in one of the 700 threads that already exists, that already have thousands of subscribers who would instantly see your question, who would have this kind of information for you..
I mean, why not create a whole new thread for a simple question that's been covered...lol
First "real" widebody M3 ever thread.[url]http://www.m3post.com/forums/showthread.php?p=17461963
6ixSpd6011.50 |
03-14-2017, 11:20 AM | #12 | |
Crazy!
1180
Rep 1,440
Maxf80M3174.00 |
03-14-2017, 02:07 PM | #13 |
Rep 3,387
Yuuuuupppp, b/c they can definitely tell when your DME has been flashed, which is required for the s/c'er.
03-14-2017, 02:11 PM | #14 | |
///M Powered for Life
11469
Rep 10,328
There is data out there that shows ARP bolts distort the bore and make the problem worse, so you should either use OEM or BE-ARP bolts. OEM bolts are quite difficult to install. I doubt a shop will ever install OEM bolts to spec, because any mistake requires you to throw the bolt away and use a new one. Unlikely... |
Maxf80M3174.00 |
03-14-2017, 04:50 PM | #15 | ||
Boost Addict
174
Rep 460
F80 BMW M3 DCT YMB
03-14-2017, 06:52 PM | #16 |
Rep 10,589
I believe VAC sells a proven ARP bolt as well. Malek uses them.
And Lang Racing uses a Carillo bolt with success. Stock bolts work fine. They just take longer to install due to the torque sequence. There is no reason to screw it up. If you could not do it properly you should not be installing bearings in the first place. |
03-14-2017, 10:57 PM | #17 |
Rep 217
If ARP has a preferred bolt, that they produce, than anyone should be able to get it.
What are the preferred part #'s? ...or, is it some vendor "special sauce" BS?? Someone with the "BE-ARP" bolts please relay the part# from the box. -Mark in St. Louis |
Maxf80M3174.00 MilehighM3912.50 |
03-15-2017, 05:15 AM | #18 |
Boost Addict
174
Rep 460
This is exactly what I was looking for ... thanks
F80 BMW M3 DCT YMB
03-15-2017, 07:42 AM | #19 | |
11469
Rep 10,328
The bolt called 'ARP' distorts the bore. This was measured in the S65 and was already a topic in the S54. 'Really strong bolts' are not necessarily a good thing as they will overclamp and bend the cap by themselves. This is why when I did the S54 rod bearing DIY I used stock, OEM bolts. OEM bolts do not fail, they are simply a pain in the ass to install. BE had ARP build a different bolt, known as the BE-ARP bolt. It's measured to not distort the cap, so it is like OEM but with an easier install. As far as I know, the BE-ARP bolt is only sold on the BE webpage. |
Maxf80M3174.00 |
03-15-2017, 08:25 AM | #20 |
Rep 10,589
There is much to read on the subject:
http://wiki.rcollins.org/core/index..../S85_Rod_Bolts But the bottom line is that plenty of people have used all these bolts -- OEM, Carillo, ARP 625 and ARP 2000 with no issue. Even the ARP instructions say to measure the bore rather than to rely on a torque spec. Of course you cannot easily measure the bore on an installed rod, so most of us cannot torque based on bore measurement when changing rod bearings. We have to rely on a torque spec. Those who have tested, like Lang Racing and BE, have come up with torque specs different from what the rod maker suggests. |
Maxf80M3174.00 Locksmythe48.00 |
03-16-2017, 12:33 AM | #21 | |
Rep 217
Has anyone actually picked up the phone and called ARP???
-Mark Quote:
