12-16-2016, 07:56 PM | #1 |
Rep 412
PFC Direct Drive Rotors and OEM Pads - Compatible?
For Direct Drive Rotor use with OEM calipers:
1. Can you use the OEM pads for street use with the DD rotors or do they have clearance issues with the rotor hats? 2. Are there any downsides to using these or are they really an upgrade with no compromises? |
12-16-2016, 08:37 PM | #2 | |
just another M3
514
Rep 1,150
///M3... Don't want more power, Just want it to turn sharper one step closer each time. -Ohlins TTX Raceline, PolePostions seats, Akrapovic EVO, ARC-8, 1/2 Cage, Seat Delete, Stoptech BBK, solid Subframe and diff bushing, spherical bearing on everything.
Theodore668.50 |
12-18-2016, 12:39 PM | #4 |
Thread killer
635
Rep 1,895
As far as downsides go, I suppose cost could be considered one, since the OEM rotors are really sturdy and robust units. Some people will get bent out of shape since PFC doesn't make a matching dimpled rear rotor, so you'd be running dimpled front PFCs and OEM cross-drilled rears. I didn't find it noticeable at all and I'm flagrantly OCD. The other thing I've noticed with E9x PFC DD v2 rotors is an odd whirring type of noise they make when driving around. It's not really bothersome but the sound is different -- don't know how else to explain it.
Theodore668.50 |
12-18-2016, 02:51 PM | #5 |
///M Powered for Life
11469
Rep 10,328
if you track, they're as close to an upgrade without compromises as you're going to get
they are expensive, but they're massively more durable than OEM rotors and than some aftermarket BBK rotors, like Stoptech |
Theodore668.50 |
