10-29-2015, 05:32 PM | #1 |
Rep 2,910
Drives: 2011 E93 M3
Parting out: 2009 M3 Convertible & (2) TWO S65 engines
I have tons of good engine parts for S65. Let me know what you need. Smaller parts prices include shipping. Oil Pan 1 (has quality TIG weld repair) SOLD Oil Pump sets $400 each Crankshaft 1 (will need to be cleaned up- should still take std bearings) $900 SOLD Crankshaft 2 (good to go) $1400 SOLD Rods, $60 each Used pistons, $25 each ALL SOLD Heads w/cams/vanos $800. Head set complete w/cams- rebuilt 0-miles $2500. (not pictured) VANOS adjusters $100 ea Timing Chains $40 ea Valve covers $140 each. VANOS solenoids $60 ea Cam Sensors $25 ea Intake Throttle bodies, ITB's, $250 per side or 450 per set Fuel Injector Rails with injectors $120 ea Throttle actuators, known good, $300 ea Idle control Valves, $100 Starters, $100 ea Water pumps (good), $100 ea Thermostat housing assemblies, $40 ea Coils $40 each. Oil vapor separators $40 ea Headers w/ heat shields, $450 set Flywheel, 6spd $100 Alternator, $100 Power Steering pump, $280 A/C compressors, (removed working + under pressure) $150 Pics before disassembly: Last edited by deansbimmer; 05-17-2017 at 09:41 AM.. |
11-04-2015, 11:34 AM | #2 |
Rep 2,910
Drives: 2011 E93 M3
Bump
11-24-2015, 07:33 AM | #4 |
Rep 2,910
Drives: 2011 E93 M3
Bump, still have lots of parts!
11-25-2015, 10:23 AM | #5 |
Rep 615
Drives: E92 M3 6MT Space/Black
Hello Dean,
Awesome list of parts ! Quick question...I see you have a good crank in the listing. If someone were to experience rod-bearing failure, to the point where the crank is damaged, is the solution simply to replace the crank with new bearings (and possibly the rod if damaged) ? I hear of people doing entire engine swaps for a failed bearing. I have access to a shop and would like to know that its possible to just change out the broken parts. Thank you for your time ! GM |
11-25-2015, 11:16 AM | #6 | |
Rep 2,910
Drives: 2011 E93 M3
11-25-2015, 12:43 PM | #7 |
Rep 615
Thanks for the reply!
I see your point in the ease of simply replacing the engine altogether...or replacing what's needed if you have the shop/tools. I'm actually just entertaining the idea of building a spare engine for: 1.) just for fun 2.) to have a back-up. Really a pretty machine to look at and I would rather spend my money on building an engine than paying thousands for a warranty that I may never even use. GM |
11-30-2015, 12:11 AM | #9 |
Rep 2,910
Drives: 2011 E93 M3
No oil cooler anymore sorry.
11-30-2015, 09:23 AM | #11 |
Rep 2,910
Drives: 2011 E93 M3
One had 47k, the other 56k.
11-30-2015, 11:56 AM | #13 |
Rep 2,910
Drives: 2011 E93 M3
No intake plenum. Just the throttle bodies.
12-03-2015, 09:30 PM | #14 |
Rep 529
How much for the idrive knob, and the trim it's attached to? (don't need lcd screen and nav brains)
Instagram: That_M_Power
E93 M3 AC Schnitzer Carbon Fiber - Fully Gutted Exhaust and muffler delete | 2007 DB9 Bone Stock | 2016 428i |
12-04-2015, 08:49 AM | #15 |
Rep 2,910
Drives: 2011 E93 M3
The control knob is gone but I have the leather console top for 120 shipped.
08-06-2016, 09:37 PM | #16 |
Rep 14
Dean, Spoke with you on the phone a couple weeks ago. Got the engine out and it is looking rough. Have you acquired a block yet? Mine is looking like it is done.
Thanks. Jeff |
08-07-2016, 08:52 PM | #18 |
Rep 12,733
i just thought i'd ask since you part out a lot of M's- do you have any inner LCI tail lights for an e92?
08-07-2016, 09:04 PM | #19 |
Rep 2,910
Drives: 2011 E93 M3
Hey guys:
I have not found a stock block yet. I do have center vents $50 shipped with buttons. I do have LCI inner e92 tail lights. |
08-08-2016, 09:12 AM | #21 |
Rep 2,910
Drives: 2011 E93 M3
