03-24-2015, 08:08 PM | #1 |
Rep 12,654
AutoTalent | KW Suspensions largest dealer! Free shipping! KWV1 | V3 | H.A.S | e9x M3
Golan@AutoTalent.com AutoTalent | KW Suspension | BMW e90 e92 e93 M3 | Applications: V1 | V2 | V3 | ClubSport | H.A.S. We are the LARGEST KW Suspension dealer! So we can GUARANTEE the lowest price! KWV1: Factory Pre-set Damping The Variant 1 is KW's basic simple and effective coil over kit that is still packed with lots of features - Pre-set damping optimized for a blend of ride comfort and handling with less bodyroll than the standard suspension, Stainless steel strut/shock bodies and composite spring perches for superior corrossion resistance, Individually height-adjustable: Front = 10-40mm lowering Rear = 5-35mm lowering, TUV approved lowering range and operation, Expert engineering and design for ease-of-use and long durability, This is the ideal coil over kit for a E9x M3 owner who does not plan on tracking or autocrossing the car and just wants a lower, more aggressive stance and better handling. KW has set the shock damping rates to be an excellent balance for a smooth yet taut ride, and to resist bodyroll motions for better handling. The Variant 1 differs from the Street Comfort set in that it has stiffer springs and revised shock settings. If you want a sportier ride and better handling than stock the Variant 1 is an excellent choice. Coil over suspensions are better engineered suspension options compared to a standard shock + spring package. Since the springs and shocks in a coil over are designed by a team of engineers to work together, there is much better suspension travel and more precisely tuned specifications for spring and shock rates. Using separate shock and spring specs may result in premature coil bind or shock bottoming. And most coil over kits offer more features than the traditional packages. Coil overs are also more useful when larger wheels/tires are used because you can precisely set the ride heights to clear the new tires. KWV3: Adjustable Rebound & Compression Damping Want full control? The KW V3 gives you multiple settings for both rebound and compression. You have full access over ride comfort and handling to dial in that perfect setup. Race teams rely on adjustments to get that perfect lap time and having shock controls at your fingertips is key. KW V3 features - Separate adjustments for compression (14 positions) and rebound (infinite settings), Stiffer springs over stock for less bodyroll than the standard suspension, Stainless steel strut/shock bodies and composite spring perches for superior corrossion resistance, Individually height-adjustable: Front = 10-40mm lowering Rear = 5-35mm lowering, TUV approved lowering range and operation, Expert engineering and design for ease-of-use and long durability, Whether you track the car often or only use it for backroad carving the V3 will give you the tools to set up an ideal handling condition. You can crank it up for smooth and fast surfaces or soften it for city or rough roads. Since each shock is 2-way adjustable you can alter the front-rear balance to account for brake dive or squat during power application coming out of the corner. You are in total control! Coil over suspensions are better engineered suspension options compared to a standard shock + spring package. Since the springs and shocks in a coil over are designed by a team of engineers to work together, there is much better suspension travel and more precisely tuned specifications for spring and shock rates. Using separate shock and spring specs may result in premature coil bind or shock bottoming. And most coil over kits offer more features than the traditional packages. Coil overs are also more useful when larger wheels/tires are used because you can precisely set the ride heights to clear the new tires. KW ClubSport: Adjustable Rebound & Compression Damping, Front Camber Plates & Stiffer Springs KW Clubsport coilovers was developed for E90/E92 M3 & E82 1M Coupe owners who demand a better handling car when participating in track day events, but also require a setup that could be used every day. The Clubsport was specifically designed for the Nordschleife using track day tires. By using the adjustable camber mounts, the suspension geometry can be adjusted to the requirements of tires and the intended use. The mentioned adjustment options combined with the independently adjustable rebound and compression damping technology allow a suspension setup according to the vehicle load, tire characteristics and different track conditions. KW Clubsport meets every demand regarding a coilover for the usage on the road and the race track. KW Clubsport suspension kits are independently adjustable in compression and rebound and include high performance racing springs. Racing front camber plates are included for further performance. KW Clubsport guarantees excellent handling, best performance, highest agility and fantastic lap times. Height adjustable coilovers: Front - 10-40mm Rear - 5-35mm *Performance setup for the racetrack *Dampers in compression & rebound forces independently adjustable *Use of high performance linear race springs: Front 510 lbs/inch, Rear 800 lbs/inch. *Stainless steel technology "inox-line" Includes front camber plate mounts KW H.A.S. KW H.A.S - Height Adjustable Spring kits are a great alternative to conventional springs. You can adjust the height of your vehicle with the KW height adjuster. These kits are ideal for cars with either stock type shocks or the factory EDC - Electronic Damping Control - shocks, as the factory EDC system is retained. This lowering solution from KW optimizes the dynamic performance and steering behavior while still using the factory EDC system. This kit contains vehicle specific adjustable spring seats with adjusting KW lowering springs. This complete conversion allows an individual adjustable lowering solution. *Individual height adjustability *Works with EDC and Non-EDC suspension. *Improved looks and vehicle dynamics *Optimal Performance *Better steering Lifetime warranty! How to Place Your Order: Phone Domestic: (855) 973-2757 X 104 Phone International: (310) 231-7800 X 104 E-mail: Golan@AutoTalent.com Website: www.AutoTalent.com Payment: Installations: Feel free to visit us at our facility in Los Angeles, CA. We install everything we sell. 19143 S. Hamilton Ave Gardena, CA 90248 Shipping: All orders are shipped via FedEx, UPS, USPS and Pilot. International, Hawaii and Alaska customers: Please contact us for the best quote possible. Hours of Operation: Monday through Friday: 10AM-7PM Pacific Time Saturday: By appointment only Last edited by AutoTalent; 10-18-2017 at 02:37 PM.. |
