02-21-2015, 01:00 PM | #1 |
Rep 363
Best Tire brand & size for e92 m3 CP.. 19" ZCP
Just got a 2011 e92 m3 Competition Package, so the tires I have now are 265 in the rear, i thought it should be 285 for more grip, also what are the best brand? I figured the Michelin Pilot sport's or super sport would be the best, anyone thinks they know of a better tire please let me know, thank you. Also I drive it on the street, daily.
02-21-2015, 02:12 PM | #2 |
Rep 734
I'm not convinced that width=grip is a correct statement. I say it's more about tread compound and design, sidewall design and tread depth.
Nonetheless, I have 295/30/19 PSS on my ZCP E90 and I'm very happy with them. Well, I don't have them on right now - they're just stacked up in storage. Right now I have X-Ice 3 245/40/18 ... ugh.
... a glorious V8 that screamed and hollered as the revs rose and then howled in an orgy of what sounded like BDSM ecstasy as it neared the red line.
Well, you can forget all that. The new car is fitted with a turbocharged straight six. Turbocharging? In an M car? That’s like putting gravy on an ice cream. - Jeremy Clarkson, discussing the S65 and then S55 M3 engines. |
02-21-2015, 02:22 PM | #3 |
Rep 1,385
I currently run 255/35/19 fronts and 285/30/19 rears on the stock 220M wheels
I'm using conti 5ps
2011 E90m3 ESS G2, active auto x pipe, RK FULL E85, DD
2015 X5M Bootmod3, Downpipes, Mineral white-The wifes DD 1994 300zx 2jz Swapped slicktop- The toy/track car |
02-21-2015, 02:23 PM | #4 |
Rep 1,186
I like the 255/275 PSS combination for street. Gets just the right grip in first and fits the zcp rim width really well. So close to stock rolling that the mdm (especially euro) works fantastically. Also very cosmetically pleasing, just the right tire beef. Hope this helps
R8 V10 6MT
S65 M3 Tesla 3 |
02-21-2015, 08:05 PM | #6 |
Rep 363
thank you all, so i guess most will agree the PSS are probably what you want, I would be interested in trying the 255/275 PSS set up to see how it feels, with the OEM spec i feel like its too tail happy, i want it to hold more in the turns. : )
02-21-2015, 08:07 PM | #7 | |
Rep 1,186
R8 V10 6MT
S65 M3 Tesla 3 |
02-21-2015, 10:32 PM | #8 | |
Rep 817
Drives: 2013 E92 M3
02-22-2015, 06:37 AM | #11 |
Rep 1,385
Side wall ratio has more to do with grip then sheer throwing a wider tire on the car. There is a reason drag cars have 40 plus ratio side walls and not 30s on 305. A tire that is just wide but has no give equals no grip. Ofcourse this changes as you move on to a racing compound for say r888s or NT-01 even piloit cups but regualr street performance tires not so much.
02-22-2015, 06:30 PM | #13 |
Rep 1,835
Drives: 2020 X4M CS
All good points, my only advice is keep the stock stagger of 20-30mm difference if Handling is ur priority. BMW engineered it likeep that for a reason...
Also the wheel width is not the same as the contact width. Michelin PSS have "wide shoulders" so a 275 Michelin PSS actually has a wider contact surface than say A Hankook via evo. the first number in a tire size is the width at the fattest part of the tire..again different than the contact point. I've run 3 settings, oem 245/265...Hankook 255/275...now PSS 265/285... In my humble opinion 255/275 was the perfect balance. Current setup 265/285 michelin PSS rub with a 1" drop. That's with a 35% aspect ratio and 25mm offset. A 30% AR would rub less but lessen traction and make for a bumper ride. |
02-23-2015, 06:26 AM | #14 |
Rep 228
I use the 255/275 Michelin Pilot Sport A/S 3 - Y rated
I love them. They seem more grippy than the summer perellis that came with the car.... The perellis on the back lasted maybe 8k miles and were horrid in the cooler months Just replaced my rear Michelins after 24k miles these puppies last http://www.tirerack.com/tires/tires....Speed+Rated%29 |
02-23-2015, 06:04 PM | #15 |
Rep 734
MAYBE slightly lessen traction in a straight line. But stiff sidewalls are essential to good handling.
Rougher ride? Agreed.
02-23-2015, 06:46 PM | #16 |
Rep 1,835
Drives: 2020 X4M CS
02-24-2015, 04:54 PM | #17 |
Rep 2,982
When I had the stock contis at 245/265 and stock MDM, after about 6k miles the car was always skittish due to crap tires and intrusive MDM.
Then I got stock size 245/265 Michelin PSS. They were great...still broke traction enough to get the DSC to kick in which was annoying. This thread made me realize that right after I got Euro MDM, I never really break traction bad enough to snap my head forward. In other words I get to retain the quick steering front end feel with the stock slight understeer nature of the car. The tiny bit of extra slip angle the euro MDM provided was the trick. PSS is the best tire also. Cannot be happier. |
02-24-2015, 08:42 PM | #18 |
Rep 595
If you are breaking traction on the street you are driving too aggressively. Slow down. There are plenty of places to hoon your car legally.
02-25-2015, 05:22 PM | #19 |
Rep 868
Drives: 2011 E90 M3, Jerez Black
If you are looking for general use tires instead of dedicated track day tires, the Pilot SuperSport is the only way to go.
Tags |
bmw, bmwm3, help a noob, help me, tires |
