07-25-2012, 07:56 PM | #1 |
Rep 1
Help Please
Hi, i am new to this forum and need some help please i have a 2009 e92 m3 dct and have started to have some problems with it recently first of all every tome i used to start the car it used to display battery discharge and since yesterday when i was driving normal in auto mode when i slowed the car down to come to a stand still it jerked and then said transmission failer and wouldnt change gear and went into limp mode then i turned the car off and back on and it was fine and today it has done the same thing a few times any idea what it could be?
07-25-2012, 08:03 PM | #2 |
Rep 13,093
Drives: BPMsport 2012 E92 M3
Garage List 2013 Nissan GTR [0.00]
2019 Sierra Denali ... [0.00] 1999 Nissan Silvia [0.00] 1999 Nissan Skyline ... [0.00] 1998 Toyota Supra [0.00] |
Get the codes and let us know.
08-06-2012, 02:24 AM | #4 |
Got my license back!
14
Rep 205
CF31
CF33
aFe cold air intake system (stage 2) ▫ Agency Power cat delete/section 2 midpipes ▫ Agency Power exhaust system ▫ Beltronics STiR Plus ▫ BMW M style (ZHP) weighted short shift knob ▫ CIC iDrive ▫ Clutch pedal spring removal ▫ Coding ▫ Evolve-R tune ▫ Laser Interceptor ▫ LUX H8 V3 Angel Eyes ▫ pickyeater334 clutch stop ▫ Rear fog lights (2011 light control switch assembly) ▫ T3 Alpha laser gun protection ▫ Turner Motorsport power pulley kit
08-08-2012, 04:20 AM | #5 | |
Rep 735
08-08-2012, 07:50 AM | #6 |
1122
Rep 7,690
All related to your battery dis-charge.
BMW batteries get weaker and weaker every time they drain and get recharged.Get your battery replaced and clear the codes and you are good to go. Good Luck ! |
08-09-2012, 05:34 PM | #7 |
Rep 735
Things have now turned sinister ..
4BE3 Message (transmission data, 0xBA) 4BE8 Message (transmission data, 0x1A2) 4DF3 Message (torque transmisson, 0xB5) Although this is clearly pointing towards the box .. does anyone have an expanded definition of the codes ? |
08-09-2012, 06:19 PM | #8 |
Rep 873
08-10-2012, 09:00 PM | #9 |
Rep 7,541
Change the battery.
Low battery voltage can cause tons of sporadic faults in many different control units. After battery replcement, ensure that a batter reset is performed so the IBS system adjusts it's monitoring values. Make sure you have atleast 12.2V with the car off (preferably 12.5), and > 13.9 with engine started. Then clear all the faults and you should be good to go.
08-10-2012, 09:22 PM | #10 | |
Rep 1,359
Hey, man!! Didn't know you returned. Good to have you back!! PS: tried to PM this message but your box is full
2014 E63 AMG-S
2012 C63 AMG (P31) - gone 2011 E90 M3 FBO - gone |
08-10-2012, 09:24 PM | #11 | |
DHS
201
Rep 4,007
Drives: 2023 M4, 2020 Land Rover
2020 Land Rover Velar Autobiography
2023 BMW M4 2016 X3 |
08-10-2012, 09:44 PM | #12 | |
Rep 1,253
Drives: F10535, E90M3, E30M3, E28M5
Garage List 2017 Alpina B6 GC [0.00]
2014 535xi M Sport [0.00] 2014 X3 3.5 M Sport [0.00] 2011 M3 E90 [9.74] 2007 Z4 M Coupe [7.00] 1990 M3 [9.50] 1988 M5 [10.00] |
And Good Luck as well!
ESS VT-1 550 | M24 Oil Cooler | Fall Line Half Cage | RaceTech 4009W | 6 pt Harness | Lifeline Zero 360 Fire Suppression | Rear Seat Delete | Motion Control DA Dampers w/remote reservoirs | 900/650 Hyperco Springs | RD Sport Sway Bars | Brembo 380 BBK | GC Camber Plates | Hoosier R7 | Eisenmann Sport | Stack Gauges | Painted Challenge Front Lip | Painted ZCP Rear Spoiler | Xpel Ultimate Film | LuxAngelEyes |
08-10-2012, 10:43 PM | #13 |
Rep 7,541
GIdriver: Thanks man! Much appreciated. My PM box is full, trying to get that sorted. I will PM you when it's all clear.
Heckler&Koch: Thank you!! It's good to be back, I missed you guys.
02-24-2019, 04:19 PM | #14 | |
Rep 1
Service Bulletin CF33
I later found out about a service bulletin - SI B24 10 07 (do a web search). It is a software issue. Here is the excerpt from the bulletin: SUBJECT The Transmission is in "Failsafe" mode with EGS Fault CF33 Stored MODEL E70 from SOP to 8/2007 E60, E61 produced 2/2007 to 8/2007 E90, E91, E92, E93 produced from 8/2006 to 8/2007 All with either the ZF 6HP19TU or 6HP26TU automatic transmissions SITUATION After control module replacement, complete vehicle reprogramming, or after clearing DME adaptation values, the transmission is in "failsafe" mode with fault code CF33 (No message from engine management stored in the EGS module). The fault entry cannot be cleared. CAUSE EGS software application CORRECTION Do not replace any parts. Using DIS 49.0 and higher run a "Short test" and Perform the following test module: Reset learning functions / S2460_GSLFR_TU - available using the following diagnostic path: Service Functions / Transmission Control / Calibrations / Reset leaning functions Afterwards turn the ignition off / lock vehicle / let vehicle enter sleep mode It is now possible to clear the fault. This problem is planned to be corrected with August 2007 and later production vehicles equipped with these ZF transmissions. ------------ You can also use a tool like Bavarian technic, which I did. Just make sure that you give the vehicle enough time so that it goes to "sleep mode" before attempting to clear the code. It worked for me. Otherwise, I'd have taken it to the dealer and pay them to fix a problem that should not have been there in the first place. Good luck. |
