07-11-2010, 07:09 PM | #1 |
Rep 1,680
Using extended bolts without spacers?
I left my OEM bolts at the shop and its sunday so I can't go get them, Im having vibration issues and I want to find out if its the MS spacers, can I just use the extended bolts without the spacers?
07-11-2010, 07:19 PM | #2 |
Rep 2,736
Drives: 2008 E92 ///M3 Alpine White
How thick are the spacers? I wouldn't do it....
Did you follow the DIY installation instructions from EAS?
07-11-2010, 07:48 PM | #3 |
Rep 1,680
07-11-2010, 07:52 PM | #5 |
Rep 2,736
Lol...hmmm I don't know how deep the threads are in the hubs...I wouldn't risk my wheels not being attached properly if the lugs hit the inside of the hub and make you think the wheel is tight....
Are these on the OEM wheels on your E92 that your putting the spacers onto?
07-11-2010, 08:21 PM | #6 | |
Rep 1,680
No weights did not fall off. Yes tried with another set of wheels. Yes cleaned prior to installing, and after and triple checked. Yes I torqued it down to 88ftlbs. No there is no play in the hub, rack. Will confirm tomorrow if it is the MS spacers that are the problem. |
07-11-2010, 08:25 PM | #7 | |
Rep 2,736
07-11-2010, 09:30 PM | #8 |
Rep 1,680
so it was the front spacers that gives the wheel shake?
07-11-2010, 09:35 PM | #9 |
Rep 2,736
Yup...the steering doesn't like spacers at all...even if the wheels are perfect...
The rear wheels aren't connected to steering so it doesn't create a shimmy...
07-11-2010, 09:36 PM | #10 |
Rep 1,787
Yes, the front wheels will cause the steering wheel shake/vibration. This same thing has happened to me running BBS wheels with spacers, OEM 19s with spacers, etc.
-Martin |
07-12-2010, 12:00 PM | #13 | |
Rep 18,823
Drives: BMW
Do not use extended wheel lugs without the spacers installed.
Here's a recent post regarding vibration and switching from the H&R to Macht Schnell to cure the issue: Quote:
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM Last edited by tom @ eas; 07-12-2010 at 12:15 PM.. |
07-12-2010, 01:32 PM | #14 | |
Rep 1,680
07-12-2010, 02:50 PM | #15 |
Rep 506
07-12-2010, 05:21 PM | #16 |
Rep 1,680
07-12-2010, 05:23 PM | #17 |
Rep 2,736
It's no use...I am fairly convinced you are still going to have a shimmy...
04-18-2011, 11:20 PM | #18 |
Rep 628
Back to the thread topic.
I took my wheel off and hand tightened the extended MS bolt and it went all the way to the cone end of the bolt. So why is it not a good idea to run extended bolts without spacers?
04-19-2011, 06:36 AM | #19 |
Rep 751
As long as it clears, it won't hurt a thing. In the rear, an extremely overly long bolt would interfere with the e-brake spring, but there is a lot of clearance, and you would feel it. Just put the bolt in without the wheel and check the clearance. If it contacts anything, then measure the remaining thread length to the thickness of the wheel. I mean, it's just a bolt, we ain't reprogramming the the computer here. With that said, you don’t want to leave long bolts in very long, since the unprotected portion protruding through the hub will collect debris and will rust rapidly, so removing them could be difficult
04-19-2011, 07:45 AM | #20 |
that's what SHE said!
75
Rep 1,163
do yourself a favor and get some TMS spacers. I've been running mine for months and have ZERO vibration.
04-19-2011, 11:47 PM | #21 | |
Rep 628
I turned all the lugs by hand and they're fine. Cannot think of any neg affects to this aside from what you said regrading the debris and rust. This is somewhat temporary until I get some new ones from a U.S. dealer at $3 a bolt vs $10 here in CAD. What a joke
04-20-2011, 11:50 AM | #22 |
Rep 1,245
while on the topic of bolts... anyone know the proper length that should protrude past the wheel? I ask because I noticed that when I put on my HRE's, I had slightly less protrusion than stock, which means less threads engaged. I am debating whether its worth buying slightly longer bolts, as I am only going to keep these wheels for another 2 weeks or so. Any suggestions?
2011 AW/FR Extended E92 M3... fully loaded
