06-06-2011, 12:44 PM | #1 |
i shake a lot
72
Rep 108
kw v3...i hate adjusting height!
alright so i have the kwv3 on my 09 m3 and ive been trying to dial in the front ride hight, but god damnit, its so damn hard to turn the adjuster brackets with that little wrench. Does anyone have any ideas to make it easier to adjust? is there a special lubricant or another kind of wrench out there? any help would be great. I wanna put up pics but the front ride hight is still off
06-06-2011, 01:15 PM | #2 | |
Rep 961
06-06-2011, 01:34 PM | #4 | |
One mod leads to another ...
416
Rep 2,900
Sorry ... couldn't resist.
Current: 2014 F10 M5 Previous: 2015 F80 M3, 2013 E92 M3, 2013 F10 M5, 2009 E90 M3, 1998 E36 M3 |
06-06-2011, 03:03 PM | #5 |
Rep 961
I had ClubSports and they were easy to adjust once you got the weight off them. As for greasing the assembly, most lube products will attract dirt, which makes it worse in the long run. If you only have a couple more minor adjustments to make, maybe you could use a spring compressor to take the load off the spring seat before you turn it.
06-17-2011, 12:57 AM | #6 | |
Supreme Allied Commander
3847
Rep 54,378
Drives: F80 M3
Location: Santa Barbara, AP, Brembo, GIAC, Koni, Ohlins, Performance Friction, www.hpautosport.com
06-17-2011, 01:45 AM | #7 | |
78
Rep 684
The Clubsport is easier to adjust because it has very little preload on the springs. V3 on the other hand has much more preload. Last edited by Richard@M-World; 06-17-2011 at 01:53 AM.. |
06-20-2011, 08:40 PM | #8 |
BTC maxi
222
Rep 1,124
