09-10-2014, 12:52 PM | #1 |
Rep 927
Dinan Tune - Transferable?
I'm planning to sell off my Dinan intake and exhaust parts and wanted to know if the tune is transferable from car to car? I understand I'd have to have both cars and a Dinan dealer.
TIA!
Craig Brickner
Click to Join: BMWCCA # 366493 |
09-10-2014, 02:28 PM | #2 |
Rep 1,246
Previously, you could buy an ECU and get it aligned with your car in E36's, but I don't know if that scales to the later models.
09-10-2014, 08:13 PM | #3 | |
Rep 7,541
Tunes are not transferable as far as I know.
09-11-2014, 07:27 PM | #4 |
Rep 664
09-11-2014, 11:45 PM | #6 | |
Rep 7,541
09-12-2014, 08:51 AM | #7 |
Rep 1,678
Drives: 2011 MCB E92 M3
You could just flash back to stock and then flash to another vendors tune. I've not heard of folks having issues going between different tunes.
2011 Monte Carlo Blue E92 ///M3 - ESS VT2-625
09-12-2014, 11:16 AM | #8 |
Rep 2,336
We have had a few E92 Dinan flashed 335's in and when we went to mod further (Meth install) we switched to Active Autowerke to tune them. In all cases it is not a simple flash back to stock and then a re write. It can be flashed backed to stock, but Dinan puts a lock on the entire DME for tuning. Once we were back to stock the Dinan block would not allow a read. We ended up doing complete DME back to virgin through Autologic. So that means a total wipe and re write. Benvo, I can't believe you have not ran into this!
09-12-2014, 11:36 AM | #9 | |
Rep 7,541
The situation you described above may apply on locked software from Dinan, but doesn't apply on the E9x M3 DME. The reason why your flashes to "stock" weren't successful on the 335, is because the tool used was only flashing the calibration/data area, and in order to remove the lock and read the ECU for additional tuning, the program area would also need to be flashed back to stock. Our tool supports flashing both the program and data area in it's entirety, but some tools do not. The knowledge of this is why I've never had to run into this situation before Hope this helps. If you want a more in depth technical explanation, let me know and I'm happy to PM.
-----| Like us on Facebook | Instagram || Tuning Information | Remote Coding |----- ----Visit us at www.BPMSport.com - Emotion. Driven. | Toll Free: (888) 557-5133---- Last edited by BPMSport; 09-12-2014 at 11:44 AM.. |
09-12-2014, 12:11 PM | #10 | |
Rep 2,336
Thanks Mike. Yes they were Dinan locked and this was not on the E9x M3. The flash to stock worked just fine. It was when reading the stock file to re tune that the block popped up.
09-12-2014, 07:52 PM | #11 |
Rep 927
Would your shop flash it back to stock for no charge, or just a standard connection charge?
Craig Brickner
09-15-2014, 12:40 PM | #12 | |
Rep 664
09-15-2014, 12:41 PM | #13 |
Rep 664
09-15-2014, 12:44 PM | #14 |
Rep 2,336
09-15-2014, 03:30 PM | #15 |
Rep 7,541
Depends on the software level it's on vs the newest flash available. That's what will determine whether it's overwritten or not (provided the UIF was written on the previous update).
