10-28-2017, 04:09 PM | #1 |
Rep 243
Camber plates with OEM shocks??
I am taking off a JIC ZMS-S coilover set on the front (rears already removed) and I was wondering about recycling the camber plates from those and re-using them with the OEM EDC front shocks.
Does this make sense? If it does, what might I achieve? The stealer is doing this and the alignment, do I need to provide them with settings? and thanks... |
10-28-2017, 07:12 PM | #2 |
Rep 875
Assuming the top plates are compatible with the EDC dampers, you would achieve camber adjustability which is good. Also assuming the dealership will adjust your car's camber/toe to your request, yes you should provide them with those specs. I highly doubt the dealership will do that though unless you have someone you know there.
There's an alignment sticky at the top of this forum that has a lot of differing specs listed there from forum members that could prove useful to you depending on what kind of driving you do. |
10-28-2017, 08:21 PM | #5 |
Rep 243
not so simple....
stock springs, stock shocks, stock ride height w/new 18's- 255/35-18 front 275/35-18 rear street driver in the midwest- driver schools next year so with that kind of modest use, are the factory settings just fine and if so then I would keep the plates installed in the event that "one day" they may allow "non-factory" settings? or are there better settings for MY use than what the factory suggests I am on very good terms with the dealer... |
11-01-2017, 12:48 AM | #6 |
Rep 9,032
What's wrong with the coil overs?
11-02-2017, 03:01 AM | #7 |
Rep 12,725
it may not be as simple as "reusing" them. i think camber plates vary by edc/non-edc. secondary to that, a camber plate that was designed for coilovers without considering oem struts may be way off. i'd have a backup plan if you still want to have camber plates and only have one shot to take off what you're using now.
11-03-2017, 03:28 PM | #8 | |
Derbo Tuning
3607
Rep 3,022
The shaft bearing on the camber plate vary in diameter and the spring upper perch is catered to a specific spring type: 60mm ID Coilover spring, OEM Spring , etc. Vorshlag sell modular camber plates that can be converted to use with OEM shocks/springs but that might not be the case with the JIC setup. |
