11-04-2009, 06:59 PM | #1 |
Rep 54
New 09 M3 Convert Engine oil level high?
Hello, I am a new PROUD owner of the M3 convertible and I was just going through system information and noticed the system said engine level too high?.. So I brought it in and they technician said they come in filled up high because it burns more oil from the 1st break in period of 1200 miles? anyone have this problem or is the dealership bsing me.
thanks in advance! |
11-04-2009, 07:01 PM | #2 |
Rep 1,314
Yes, that is total BS. I would call the service manager of that dealership. If he says the same thing, it's time to find another place to have the car serviced.
Congrats on your new car and welcome!
11-04-2009, 07:30 PM | #4 |
Rep 1,314
Yes, it happens all the time during an oil change, or when people try to add oil. The problem is this car doesn't have a dip stick, and the only way to check the oil is with the electronic display. People have been complaining about it loudly on this forum for quite some time.
Sometimes dealerships have overfilled during oil changes, and sometimes owners have overfilled trying to top off the oil level between changes. The safest thing to do is wait until it tells you to add 1L, which it will when it needs it. However, I've never heard of one showing up overfilled upon delivery. It is possible it is a sensor problem (and not actually overfilled), but it is not acceptable to run the car for very long with an overfilled indication. The response you received from the tech. at the dealership was incorrect. It needs to be checked. BTW, ask the dealer to give you a 1L container to carry with you in the car. The Castrol 10w/60 oil in this car is virtually impossible to find anywhere but a BMW dealer, and don't think about using anything else. You'll want to have it with you when it tells you to add.
11-04-2009, 09:30 PM | #5 | |
Rep 280
09 E90 M3 DCT SSII Carbon Blk, Eisenmann Sport, RAC 19"RG63 on 255/275 UltracS, Dark Sidemkrs/Reflectrs/Grills, BMC Filter, LUX H8 V3 LEDs, V1 H/W, Ultimate Pedals & 30% Tint
11-04-2009, 09:51 PM | #6 |
Rep 5,012
Do a search on how to properly check for oil level and make sure it's overfilled first. Most folks here don't want to mess with the sensor, but once you know how it works, it's pretty accurate and consistent. I always keep my oil topped off, so no need to carry a bottle of oil in my $70K car, but to each his own. I also prefer to have it full than close to a liter low, but that's just me.
Whichever way you want to deal with the oil level situation, at least learn how to check it accurately, which is NOT by looking at the gauge while underway. And if you're a bit handy, you can easily drain the front sump (it holds 1/2-liter) if it's indeed overfilled, rather than dealing with apparently incompetent techs at your dealership, but again, that's just me. Good luck, and welcome to the family . |
11-04-2009, 10:12 PM | #7 | |
Rep 1,314
In 8000 miles, I've watched the car go from perfectly topped off at delivery, which never varied through the 1200-mile, break-in change, to 3/4 today. I've never added a drop of oil, and I've never seen a single indicator variation, no matter when or where I look at the indicator. However, I've seen various people report crazy readings on this forum, and my car is only one data-point, as is yours. From my standpoint, I'm liking this new system on my car a lot. It's saving me a wee bit of hassle, and I'm always happy to see the indication that all is well in the oil department, while running down the highway.
11-04-2009, 10:23 PM | #8 |
Rep 2,294
Mine was very slightly overfull on delivery, but we caught it on going over the car's controls; and they whisked into the shop and took a bit out.
The explanation given to the OP is just nonsense. Not an encouraging start at the dealers.
2018 340i xDrive M Perf Edtn Sunset Orange
Previous BMWs - 19 others since 1971. |
11-04-2009, 10:28 PM | #9 | |
Rep 880
So true! Congrats on the new ride. -Vin |
02-02-2010, 04:21 PM | #10 |
Rep 4
How to drain the front sump?
Hi all,
I just put in 0.6L of oil into my car after the sensor had been reading 1/3 full between the min and max levels for about a week. After driving 15 miles it now reads that it's over full. Does anyone have any quick tips for taking out oil, or do I actually need to get under the car and drain the front sump? If the latter is the case, how exactly do I drain it? Thanks! |
02-02-2010, 04:27 PM | #11 | |
Rep 1,314
If you follow the manufacturer's instructions and leave it alone until it tells you to add 1L, you won't have that problem. Anywhere between min and max levels on the electronic gauge means the level is fine.
02-03-2010, 02:15 PM | #12 |
Rep 1,007
I had an underfill message after my 2000km (1200 mi) service, took it back to the dealer and they said it was that they had forgotten to re-set the sensor, maybe they were bs-ing me or maybe that has happened to your car.
E90 Interlagos Blue, (Winter Beater) Bamboo Beige, M-Drive, EDC, PDC, USB 6MT.
Mods to date; Curb rash, Scraped front spoiler, Installed RAC Monolite RG63 Silver 1984 Porsche 911 Carrera Coupe (ROW) |
02-03-2010, 03:53 PM | #14 |
Rep 3,384
I also learned my lesson with the overfilling over the oil. The general rule of thumb is add the 1qt like it asks but it will take roughly 3 cycles of driving for the display to update properly.
02-03-2010, 05:05 PM | #15 |
Rep 255
Correcting an overfill
I think ELP has it nailed. After having to add oil occasionally, changing my oil and overfilling it, I can vouch for the both the front sump trick to remove a little as well as the ad-a-little (less than 1/4 liter at a time due to the inaccuracy of the sensor) and then asking for an on-demand oil level check while the car is on flat ground at idle.
02-03-2010, 06:03 PM | #16 | ||
Rep 5,012
Not hard to understand if you think about it: The sensor is at the very rear of the main sump (rather than at the middle), so going up or down hill affects the oil level at the sensor. Add to that running the engine at higher rpm vs idle, and it's easy to see how it can be inconsistent. Same as checking your tire pressures when hot. And no, I'm not trying to change your mind from your 'follow the manual' mentality; it's a valid opinion as well. Just want to give folks an option. I like options . Take care. |
02-03-2010, 07:02 PM | #17 |
Rep 1,314
Oh you certainly won't change my mind on the "adding oil a little at a time" issue. That's just an obsessive/compulsive, high-maintenance, waste of my time, which is far more valuable. It also opens Pandora's Box as our latest "overfiller" learned.
What I do know is that I've never once seen anyone report that they got an "overfill" message IF they waited to add oil until the car told them to. The only benefit to seeing a topped-off reading every time you drive the car is all in a person's head. But, if that makes you or anyone else happy, knock yourselves out
02-03-2010, 09:32 PM | #18 | |
Rep 1,804
Did this the last time i went for a top-up with the SA and tech standing right there, they said you will have to drive it for a few miles, but as i pressed it said ok and the 1L light went away, double confirmed through I-Drive |
02-03-2010, 10:06 PM | #19 | |
Rep 3,384
02-03-2010, 10:26 PM | #20 | |
Rep 5,012
If you enjoy totting around with a quart of oil and a funnel in your trunk like if you were driving a clunker, and having to stop and pour a quart whenever you happen to get your message, knock yourself out . Until the next thread man . Last edited by JCtx; 02-03-2010 at 10:54 PM.. |
02-03-2010, 10:36 PM | #22 | |
Rep 281
I completely agree with Foosh. Being an overly anal owner, I learned the hard way. I added a quart, but the indicator didn't display that my oil level was completely full. I ended up adding more, then getting the overfilled message a day later. It is better to just add the ammount the car asks for only when it asks for it.
