Tirerack
Use the following links to go directly to useful tirerack winter items: Tirerack Winter Tires. Gary's Winter Tire FAQ.
Using the links directly supports E90Post with tirerack sales commision!
  E90Post
The Tire Rack
   PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS!
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > RFT or NON RFT
Wheels and Tires forum Sponsored by The Tire Rack
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer
      12-21-2011, 03:58 PM   #1
glo459
Drives: 08 335i convertible
RFT or NON RFT
Anyone got any recommendations as to stay with RFT tires or should I go Non-Run flat tires?
E93 front 225/40/18
Thanks!
      12-21-2011, 08:25 PM   #2
M-Steep
Drives: 2009 E93 M Sport
E93 front 225/40/18
Thanks!
Just got Michelin PSS non-RFTs to replace my OEM Bridgestone RFTs on my E93 M-Sport (18s).
Short first take: Much less harsh over sharp hits (e.g., seams, cracks, potholes); turn-in precision/ crispness still great, if not quite as sharp; ride is silky; can't say for sure about grip around turns until more miles; straight line grip under heavy throttle seems obviously better. Getting the Conti repair kit for the trunk.
      12-21-2011, 11:51 PM   #3
glo459
Thanks for the feedback!
Do you think it'll be a problem if I use non run flats for the front, and keep the oem run flats in the rear at the same time?
      12-22-2011, 07:25 AM   #4
M-Steep
I got conflicting advice on this; decided to replace all four, though the fronts were still ok. Glad I did, w that the money's spent.
      12-22-2011, 07:35 AM   #5
driverman
Drives: 2008 328i 6MT - SOLD
Big problem. The front tires won't be as stiff as the rears which will upset the balance of the car. I wouldn't do it.
Recommend you get 4 non-RFT's. The new Michelin Pilot Super Sports seem to be the best tire you can buy. You can find tirerack's test results here: http://www.tirerack.com/tires/tests/...y.jsp?ttid=148.
      12-22-2011, 10:11 AM   #6
Gary@TireRack
Moderator
Gary@TireRack's Avatar
Drives: Formerly 1995 M3
+1
glo459, whichever way you decide to go, be sure all four tires are matching.
Tires http://www.tirerack.com/a.jsp?a=AH8&...ires/index.jsp
Gary. Tire and Wheel Forum Moderator. Tire Rack Sales Rep Gary@Tirerack.com
http://www.tirerack.com/a.jsp?a=AH8&url=index.jsp
Please refer to 'Gary/E90 Post' as your previous contact when you order online to help support this forum.
      12-22-2011, 11:46 AM   #7
Tom K.
Tom K.'s Avatar
Drives: '07 328iT, '13 Boxster
No problem - as long as you never drive on wet roads or over 25 mph on dry ones.
See Gary's post.
Tom
      12-22-2011, 12:15 PM   #8
glo459
Thanks you for all the advise! I'll be switching all four tires to Michelin PSS.
      12-22-2011, 01:17 PM   #9
VMRWheels
VMRWheels's Avatar
2038
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
+1
If you are going to make the switch to non-RFTs, you should do all four rather than just a pair. Overall though, those who do switch over are often pretty satisfied with their decision.
      12-22-2011, 01:58 PM   #10
Brian@bavarianx
Drives: E36 M3
Non RFT all the way!!!
      12-24-2011, 01:06 AM   #11
rg87
rg87's Avatar
51
Drives: E90
+1 The RFTs are heavy and cost waaay more than a good set of non-rft tires.
If you decide to go the non-RFT route, replace the whole set and buy a road side kit for flat tire emergencies!
      12-26-2011, 10:04 PM   #12
o2centre
Drives: 2008 E92 328i Jet Black
Switched from the OEM runflats to a set of Michelin PSS non-runflats a couple months ago. Thrilled with my decision. Your spine will appreciate it going over bumps (especially if you've got a sport-tuned suspension). Had them out at the track twice and performance is sweet.
      12-26-2011, 10:10 PM   #13
driverman
How about steering response and noise compared to the RFT's?
      12-27-2011, 12:23 PM   #14
witeagle
Drives: 14 BMW Z4 2.8i * 10 BMW X3
I am in the same process and going non-RFT. I just havn't made up my mind which tire to go with.
I am also pondering going with a performance all season as I don't have a winter set. On my 325ci I had winter tires and used them for one season. The car ran fine with summer ultra high perf tires. I am not sure if the 335i will react the same in the snow!
driverman's question regarding steering response is actually very good and I have the same question along with another related question about steering response/performance with an all season over a summer performance tire.
'08 335i Coupe / 6MT / Sport / Premium / Nav / Cold Weather Pkg / Space Gray / Black Dakota Leather & Aluminum Trim
'10 X3 SAV / Premium / Nav / Cold Weather Pkg / Alpine White / Sand Biege Nevada Leather / SAV Pkg
      12-27-2011, 11:20 PM   #15
o2centre
I never tracked the car with the run flats so can't speak to the difference in steering response under high performance conditions. As far as everyday driving goes though, I don't detect much change in handling. The primary difference is a more forgiving ride over bumps and ruts. The car does less of that jerky "shimmying" right and left when going over bumps.
Haven't heard a noticeable change in noise level.
      12-27-2011, 11:27 PM   #16
o2centre
Was just back on the east coast visiting my folks for Christmas. They live halfway up a mountain and my dad has Hakkapeliitta studded snow tires on his car. Loud as hell and they eat at least 5 MPG off his gas mileage. Made me thankful I don't have to worry about that here in socal!
Tags
225/40/18, e93, non rft, rft, tires
e90post
