12-17-2016, 10:19 AM | #1 |
Rep 832
Headlight condensation
I recently installed angel eyes and led turn signals on my car and noticed now that in the morning i get headlight fog inside my housing. There is no water inside just fog that eventually disappears. What could have caused this, i put water proof sealant around my turn signals and the problem still occured.
Any ideas? Thanks |
12-17-2016, 07:58 PM | #2 |
F15 daddymobile
2350
Rep 3,510
just to clarify, you opened up your headlights and installed new rings?
12-17-2016, 08:53 PM | #3 |
Rep 832
12-17-2016, 09:03 PM | #4 |
F15 daddymobile
2350
Rep 3,510
double check that the bulbs are all seated properly.
double check that the top headlight cover is seated properly.
12-17-2016, 09:06 PM | #5 |
Rep 1,350
You may just drop some water while you were replacing the bulbs. If your covers are tighten up and closed, There should not be any water issue on your headlights.
What was the condition when you were replacing the bulbs?
E93 M3 6MT , Nav, Prem, Cold Weather, Sports package, & CA, RGBW DTM with RGB Demons + Eisenmann Race + BE + ARP + Brembo GT 380s, $3AG, $5AC, $508, $6NF, $601
Please "Appreciate" If you like my post! DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue, , F85 ACC Retrofit |
12-18-2016, 12:37 PM | #6 |
Rep 832
In my garage at night, i think the door was open. Does the angel eye bulb socket have access to the inside of the headlight?
///M Power-Belgium63374.50 |
12-18-2016, 02:05 PM | #7 |
Rep 1,350
Yeap, directly inside of the headlights!
12-18-2016, 02:14 PM | #8 | |
General
63375
Rep 24,678
2- The fog (condensation) will disappear in no time . If the condensation comes back ...Something is wrong with the sealings .
12-18-2016, 03:21 PM | #9 |
F15 daddymobile
2350
Rep 3,510
Caution when doing this... if you have dust or dirt inside your housing somewhere, you could possible kick it up and spread it to areas you don't want it (projector bowl, lense, etc).
12-18-2016, 03:37 PM | #10 | |
Rep 832
What covers are you referring to? I only want to completely take apart the headlight if I really HAVE to. |
12-18-2016, 03:49 PM | #11 | |
General
63375
Rep 24,678
EDIT: In this DIY-video you can see the covers at 8:10 runtime...
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. Last edited by ///M Power-Belgium; 12-18-2016 at 03:56 PM.. |
opihi5214.50 |
12-18-2016, 05:09 PM | #12 |
Rep 832
12-19-2016, 10:32 AM | #13 |
General
63375
Rep 24,678
All my pleasure. Personal I would try first via the covers .
opihi5214.50 |
12-22-2016, 12:55 PM | #14 |
Rep 832
12-22-2016, 01:04 PM | #15 |
General
63375
Rep 24,678
Yeahhhhhh..... !!!!
I'm really glad I could help you ... All my pleasure... -Philippe.
01-20-2017, 01:41 PM | #16 |
Rep 832
Reviving this thread. I discovered that the condensation is coming in through the top headlight cover and it doesn't seem to go away. I tried adding sealant inside the cover since a foam piece probably isn't enough and the condensation got worse. It has turned into water droplets instead of fog.
I'm thinking of ordering a new top cover for the headlight(the one you access for angel eyes). Does anyone know of a good solution or part number. Thanks |
07-31-2017, 05:00 PM | #17 |
Rep 93
I am currently having the same issue, started after I installed LUX led bulbs for the rings. So far I have replaced the rubber seals on top of the headlights but that did not solve the problem. Has anyone solved this problem successfully?
Thanks |
07-31-2017, 05:13 PM | #18 |
Rep 183
I had an SA once tell me that the E92 M3's headlights were "vented" in a manner such that condensation should only appear during drastic temp changes. But that otherwise, condensation should correct itself. Anyone have any idea what he was talking about?
07-31-2017, 06:32 PM | #19 | |
Rep 1,326
if it's a true leak and the seals are bad, then there will be droplets that build up inside the headlight housing. this could lead to damage of the ballast and adaptive modules since they are at the bottom of the headlights, water can flow down and fry them.
2014 Frozen Black F10 M5 | Agency Power HFC Downpipes | Custom Open Flash Stage 2 Tune | KW HAS kit | 3D Design Lip | 3D Design Skirts | 3D Design Spoiler | IND Front & Rear Reflectors | IND M5 Badge | M Performance Steering Wheel | M Performance CF Shift Knob | Pedal Haus Pedals & Paddles | Turner Exhaust |
07-31-2017, 08:27 PM | #20 | |
Rep 832
Open the top two lids inside the engine bay, turn on headlights and angel eyes and run them for ~10 mins. That should fix the problem if it isn't a sealant issue. Make sure there is 0 humidity out when you try. |
07-31-2017, 08:58 PM | #21 |
Rep 93
Alright thats a temporary fix and I have done that to remove condensation before, even though I think its ridiculous that I have to do all that work just to clear up the headlights on a vehicle that was 70K+ new and just hit 30k miles. Can you buy the headlight seals separately is there a part number? Any help is appericiated
08-01-2017, 05:37 PM | #22 | |
Rep 832
This is the best stuff to use on headlights. |
