07-27-2013, 10:09 PM | #1 |
Rep 324
Lowering ZCP
Is it worth it to lower with competition package. As I understand it it had as somewhat different suspension set up. Does it use same aftermarket springs and/of coil overs as those without ZCP?
Thanks for the input. |
07-28-2013, 10:32 AM | #3 |
Rep 920
I lowered my 2011 ZCP with B&G springs and E36 bumpstops and the ride is better than stock with a way better stance. Especially the front. EDC is what makes some coil/sleeve packages not compatible but for springs you should be all good with anything specifics to your E9X model.
2010 E70 X5M | Black | Black | Stock for now.
2008 E90 M3 | Interlagos Blue | Speed Cloth | Sold 2011 E92 M3 ZCP | Space Grey | Black | Sold |
09-15-2013, 12:23 PM | #5 |
You got my money?
3191
Rep 4,666
Drives: Ice Cream Truck
Kw sleeves are garbage. The bottom out to easily, the rebound is too much and the rear perches are metal on metal (stock and high end coil overs have a rubber gasket) and add a lot of road noise.
I would either get BG or eibach springs which use the stock rubber gaskets that keep road noise the same as stock. Btw, my kw sleeve over is for sale. LoL.
2022 G80 M3 Competition X / 2020 Range Rover Sport P525 / 2023 Ford Raptor
