04-12-2013, 07:06 AM | #3 |
Dingleberries
76
Rep 1,246
I assume you mean the intake plenum....
See this DIY for changing the Throttle actuator. You have to take off the intake plenum so it tells you how: http://www.m3post.com/forums/showthread.php?t=735033 |
04-12-2013, 07:06 AM | #4 |
OIF Veteran
246
Rep 2,106
I think he means the plenum
Retired: '06 BMW E46 ///M3
Current: '08 BMW E60 DINAN ///M5, Interlagos Blue, SMG DINAN Stage 2 Suspension, Exhaust, Stage III Software, Front strut braces, Intakes, 13% Underdrive pulley, 3.91 Differential, RPI Scoops. |
04-12-2013, 08:23 AM | #6 |
Rep 13,093
Drives: BPMsport 2012 E92 M3
Garage List 2013 Nissan GTR [0.00]
2019 Sierra Denali ... [0.00] 1999 Nissan Silvia [0.00] 1999 Nissan Skyline ... [0.00] 1998 Toyota Supra [0.00] |
04-12-2013, 09:38 AM | #10 |
11817
Rep 23,187
engine oil cap? twist.
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs| |
04-12-2013, 09:58 AM | #11 | |
Rep 586
http://www.m3post.com/forums/showthread.php?t=699859 |
04-12-2013, 10:55 AM | #14 |
Dingleberries
76
Rep 1,246
04-12-2013, 11:03 AM | #15 |
Rep 13,093
04-12-2013, 11:33 AM | #16 |
_______
169
Rep 1,088
If you are indeed talking about the intake plenum, then you need disconnect the air intake, unplug the IAT sensor (not from the plenum, from the other end), loosen (no need to remove) all eight throttle body clamps (6mm from what I can remember), then lift up.
'13 35i M-Sport X3 | JB4 Stage 1 | BMS Intake | H&R Springs | Gloss black grill | CF Wrap and Coded by me | Recaro Child Seats
'15 M3 DCT AW/SO | JB Stage 1 | RKP Diffuser | P3 | M Perf Spoiler | iND Exterior Trim | Recaro Child Seat |
04-12-2013, 11:34 AM | #17 |
Private 1st Class
23
Rep 473
Guilty as charged although the spirit was tongue in cheek more than sarcastic.
04-12-2013, 11:39 AM | #18 |
Rep 2,361
04-12-2013, 12:07 PM | #20 |
Rep 13,093
You cannot separate the halves without likely destroying it. It is two pieces molded together. Those nuts on the top DO NOT separate the two pieces.
04-12-2013, 12:17 PM | #21 |
Rep 996
Like The Tech said, its one piece. I have a bolt on top missing because I think the previous owner tried the same things and its gone, or heat from the Nurburgring. You loose the bolt you have to buy a whole new plenum hence why I still have one missing. $$$$$
04-12-2013, 12:24 PM | #22 |
Rep 996
I did a quick search and found this. I have never attempted to remove it but maybe this can help you.
http://www.m3post.com/forums/showpos...33&postcount=3 Here is the full thread for more on it from others. http://www.m3post.com/forums/showthread.php?t=275547 Good Luck! |
