12-17-2008, 11:56 AM | #1 |
Rep 1,417
M3 - What will BMW do first? DI or TT
What will BMW do first:
BMW will incorporate Direct Injection on the current 4.0 V8, or BMW will replace the current 4.0 V8 with a new Twin Turbo V8? I am holding out for a NA engine with DI. However the TT is going to be a Monster! Red
2011 1M, Valencia Orange, All options.
August 8th ED (#293 of 739 or 740) 88 E30 M3 100% OEM 73K Miles 02 E39 M5 Le Mans Blue 50K Miles 06 E46 M3 ZCP 58K Miles Last edited by Redadair; 12-17-2008 at 01:21 PM.. |
12-17-2008, 12:09 PM | #2 |
Rep 106
Neither...if the go TT I could see them going down to a 6 cyl. They have to leave room for the M5 and M6 to go to a TT 8 cyl so M3 would probably be smaller. They might DI to help with fuel economy...10-15%?
12-17-2008, 12:13 PM | #3 |
Moderator
7512
Rep 19,368
Both of BMW's modern turbocharged motors, the N54 inline 6 and N64 V8, feature HPI (direct injection). I suspect M will follow suit, and incorporate both at the same time as well. They've almost surely done this already for the X6 M (though we don't have engine details yet), which uses the N64 as a basis for its engine, and the M5 is supposed to get the same (or very similar) motor too.
I also agree with Born2Panic - M5/M6 will get a V8 as we know, so M3 almost surely goes back to an I6. The only other possibility would be a smaller displacement V8 for the M3 which is possible but not really likely. |
12-17-2008, 01:12 PM | #4 |
Rep 1,417
I tend to disagree with the idea of going back to a 6 in the M3. The reason is this, they already have the N54 engine for the 335i that makes 100 HP per liter. The current M3 HP is 415 from a 4.0 Liter engine. If they were to use the 6 they would need to increase the size of the engine to 3.5 or 4.0 Liters to be in the ~425 HP range.
This is where I have the issue. BMW likes to stay at a max of 500 CC per cylinder, however they did push this limit somewhat in the previous M3 motor by increasing its size to 3.2 Liters. This is the original reason they chose to use a V8 in the e90 M3. I see a new 4.0 Liter V8 Twin Turbo tuned to its upper limits reaching ~450 HP and Torque. They are going to want to hit a home run with this engine since they are closing a major chapter in the history of Naturally Aspirated engines in the M cars. I am still hoping for an interim upgrade to the current NA V8 of Direct Injection, though it may never happen. Red
August 8th ED (#293 of 739 or 740) 88 E30 M3 100% OEM 73K Miles 02 E39 M5 Le Mans Blue 50K Miles 06 E46 M3 ZCP 58K Miles Last edited by Redadair; 12-17-2008 at 02:50 PM.. |
12-17-2008, 01:38 PM | #5 |
Rep 1,668
You mean 500cc per cylinder................
Future is hard to predict, it`s all about economic devellopment IMHO....... Could be less HP and less weight in future cars.....................( Just to make Al Gore a happy guy) |
12-17-2008, 01:52 PM | #7 |
chris
278
Rep 12,144
+1
there probably wont be any changes to the engine until the end of production. they'll introduce all the new "innovations" with the next gen m3
12-17-2008, 02:49 PM | #8 | |
Rep 1,417
Red
August 8th ED (#293 of 739 or 740) 88 E30 M3 100% OEM 73K Miles 02 E39 M5 Le Mans Blue 50K Miles 06 E46 M3 ZCP 58K Miles |
12-17-2008, 03:09 PM | #9 |
Rep 1,504
I wish they would have incorporated DI into the current 4.0 V8 but it's still a sweetheart of an engine. Here's a look at Porsche's DI system for their Cayenne V8:
12-17-2008, 03:45 PM | #11 | |
Moderator
7512
Rep 19,368
Here's what we know is coming soon: N64 derived M V8 with 500hp+; most powerful M motor ever. This goes into the X5 and X6 M, and reportedly (and significantly) the F10 M5. Details of this motor are not available yet but its nearly certain that the power gains over the standard N64 come not from displacement but from more boost and probably other changes to support that such as stronger bottom end, different cams maybe even different heads. Could be designed for higher RPM power as well. Anyway, if this all comes to pass, then a M3 with an N54 derived motor (or something similar) is a likely bet. If you are still in doubt, just keep in mind that on the market today there are 2L turbo charged motors making nearly 300hp. So with 50% more dispacement, a 3L inline could surely make 450hp or so, especially with some of the worlds best engineers responsible for its design. |
12-17-2008, 03:55 PM | #12 |
Rep 154
My opinion is also a twin turbo inline 6 with DI at 400hp+
What BMW SHOULD do is reduce the weight of the car. Better performance and fuel economy...surprise Time to dream....a 3200-3300lbs car...ohhhh. |
12-17-2008, 04:57 PM | #13 |
Just call me J.J. McClure
156
Rep 2,834
+1
MODS: Meisterschaft GT Racing Exhaust / BMC Air Filter / UUC SSK & DSSR (Modded)/ RPI Scoops / Passport SRX Hardwired / Custom Wrap 3M Clearbra / 20% Tint / 50% Windshield Tint / Key Hole Delete / Matted Out Accessories / VRS Type II Diffuser / Smoked Reflectors / Euphoria 6K LED Interior Lights / Rear Fog Light Mod / 6000K HID's / 6500K LUX H8 Angel Eyes / RDash License Plate LED Kit / LED Xenon Reverse Lights
"M3 drivers have no friends" |
12-17-2008, 05:44 PM | #14 |
Rep 28
With the new M3 coming in 2013(?) or so i think it's a no brainer that BMW will implement DI on the engine. Based how mow much time till the next engine, and the fact that they already have it being used in other BMW engines. More HP with increased efficiency, especially in a time when MPG is getting more and more scrutinized , what engineer is going to say no to that? I would say expect a mid-life update with DI.
Also seeing as it would definitely give the M3 more hp, it would keep it competitive with the new Audi RS5 and other possible competitors. |
12-17-2008, 06:25 PM | #15 | |
Rep 1,417
While its true engines like the Mitsubishi Evo 2.0 make close to 150 HP per Liter, and a 3 Liter BMW engine could be tuned to this level equaling 450 HP engines tuned to this level usually provide a very peaky power band. I’ll still keep my bet on the V8 at this point, but I could be wrong. Its interesting to look at the possibilities for the next M3. If the current E90 M3 has 3 years or so production ahead of the next new M3, I think it may still be reasonable to think BMW may add DI to the current engine as a mid model upgrade, especially if the competition continues to push the HP numbers up. Again, Why didn’t BMW add DI to this current engine? This is the single biggest technology omission that they could have done to the new M3. Red
12-17-2008, 06:52 PM | #16 |
Rep 2,324
well said, completely agree.
"You will get there, but it is up to you and you alone. It is what you are willing to do, and how you are willing to get there. You must be relentless, you must be tireless, you must pursue at all costs, so that you are ready, when the time is right." -Dad
12-17-2008, 07:42 PM | #17 | |
Rep 1,504
12-17-2008, 07:50 PM | #18 |
Rep 362
Would love to see less weight, but in a world where the new Z4 is now pushing 3500lbs, I'm not holding my breath. It really is going to require the next 3 series platform to get smaller to make a dramatic dent.
12-17-2008, 08:03 PM | #19 | |
Rep 154
BMW did announce no more V-8 for the next M3, it will be a smaller engine if true. The math is there, to motivate a car in a certain weight to a certain performance, you will need a certain amount of power. With that, the next M3 will perform better than the current, if you assume this. I think with the CF roof and the CSL, BMW proved to be willing to go with radical materials to achieve weight savings. BMW if you're reading this, it is time to go Aluminum chassis! Again, fantasy talk...haha. |
12-19-2008, 02:26 AM | #21 |
Moderator
7512
Rep 19,368
