11-12-2018, 07:27 PM | #1 |
Rep 369
Moved car with dead battery and power steering shit itself.
Aloha guys and gals. I recently moved my M3 with a dead battery into my buddies garage. We had the car in neutral but had to move the wheel multiple times to get the car off the trailer and into his garage. I went to work on the car the next day and there was a puddle of power steering fluid on the ground. We didn't move the wheel past the allowable cutout. I went back to work on the car today and all of the fluid is gone from the reservoir. I'm not sure if I'll be able to drive it home or what I could have damaged. Any help is appreciated.
Ian |
11-12-2018, 10:11 PM | #2 |
Rep 801
You’re going to have to figure out why it lost fluid. Turning the wheel with the engine off is not going to cause that.
11-12-2018, 10:22 PM | #3 | |
Rep 1,612
That's exactly what happens when you turn a wheel when the tires are on the ground and car not running Clean up your mess, fill it and send it Just pushed a e46 in after blowing the water pump into pieces And forgot to suck some Fluid from the res and just poured fluid all the way into the shop lol |
11-13-2018, 01:50 AM | #4 | |
Rep 369
Problem is I don't have time to figure it out right now and take everything out from underneath to get the rack. I'll just figure it out next month. |
11-13-2018, 01:56 AM | #5 | ||
Rep 1,612
So this happens to me about every month on one car or another . You didn't do anything wrong , just made a messy . Fluid res up to half way mark, run it and go lock to lock and get the fluid through it Shut it off and check it till correct level Basically ... this never happened and I won't tell anyone if you don't Lol |
IanMan384.00 |
11-13-2018, 07:38 AM | #6 | |
Rep 369
Thanks for the help man. But I'm still wondering... where did the fluid come out of? |
11-13-2018, 07:56 AM | #7 |
Rep 2,907
Drives: 2011 E93 M3
The fluid overflowed from the reservoir cap vent. It's the only opening in the system. If it didn't come from there then you have a leak elsewhere. Clean up and carry on.
IanMan384.00 StripclubDJ4100.00 |
11-13-2018, 07:58 AM | #8 |
Rep 369
Makes sense, but I believe it ended up leaking on the driver's side. I can't wait to see what I have to fix next, lol.
11-13-2018, 01:38 PM | #9 |
Rep 4,250
Drives: 2017 M3 MG/SO ZCP DCT
Dead battery on e92 is a nightmare, mostly cause you gotta put a jumper on to get the trunk released. Glad I've never had to move the car with battery dead.
