06-11-2015, 04:39 PM | #1 |
Rep 794
Subframe and differential bushings
I have an appointment on Monday to drop my car off at MRF to get the differential and subframe bushings done. Does anyone have these switched out yet? Thoughts?
Update: Picked up my car yesterday from MRF. Ended up doing diff and subframe bushings. All I can say is it was totally worth it. Car responds and just feels noticeably better. Taking corners and acceleration are a huge difference. The whine is definitely there but something I think I'll get used to. With the windows down or music on, it can't be heard. I want to thank Malek for the work, he did an amazing job. Not only is he extremely knowledgable but I loved how neat and clean his shop is. Will definitely use his services in the future! Anyone contemplating this modification should definitely get on this, you will not be disappointed!
GINTANI TWIN TURBO E92/F10 M5 Last edited by Lucrecio84; 06-18-2015 at 03:03 PM.. |
06-11-2015, 05:35 PM | #3 |
Rep 794
how do you like it? did you notice a difference? if so, what did you notice?
GINTANI TWIN TURBO E92/F10 M5 |
06-11-2015, 05:39 PM | #4 |
Rep 5,498
Instagram: jellismotorwerks |
06-11-2015, 05:46 PM | #5 |
Rep 652
Yes... Mrf subframe bushings an Derlin diff bushings.
Car's rear end feels more planted and it eliminates wheel hop which was the main reason I had them changed. Now when I change gears at 8000+ rpm the car lunges forward as opposed to hoping or braking traction. Only negative is added noise in the cabin. It's loud so be prepared. I've been told that most, if not all, the added noise is from the diff bushings so keep that in mind before you install them. If I were to do it again I'd probably just do the subframe bushings and see how they perform before doing the diff bushings. Overall, I'm very happy with the performance just wish they weren't so loud... |
06-11-2015, 05:46 PM | #6 | |
Rep 3,387
Slop in the rear is eliminated, def. feels more planted and gives you the confidence to push it a little bit more around corners. I hardly even notice the (to me) barely perceptible noise anymore. If you have an aftermarket exhaust, it drowns it out, anyway. |
06-11-2015, 05:52 PM | #7 |
Rep 5,498
This
06-11-2015, 05:54 PM | #8 | |
Rep 794
06-11-2015, 05:56 PM | #9 | |
Rep 794
06-11-2015, 06:23 PM | #10 | |
Rep 6,771
Drives: 2016 BMW i8
I'm def doing the subframe mounts soon but the noise from the diff mounts turned me off so I was just going to do the subframes. But with this potential solution to quiet down the noise from the diff mounts, I may do that as well.
06-11-2015, 09:37 PM | #11 |
Rep 1,017
Drives: 2010 E92 M3 6MT
Yep have the solid derlin diff bushings, huge difference in how the car is planted/traction as well as gets rid of wheel hop.
As stated it causes some pretty loud whine noise in the cabin, even with windows down and loud exhaust and supercharger you can still hear it until you hit around 70-80 mph then it tapers off. Iv had mine is for maybe 1 1/2 years now and does not bother me much unless windows are up then... its like deep inside your ear in certain gear/speed. First thing everyone always asks when they get in car is WTF is that sound?? Know one of the companys are working on a isolator kit that may limit/remove the noise but we will see.
06-11-2015, 10:03 PM | #13 |
Rep 3,742
I have the MRF solid aluminum subframe bushings and delrin differential mounts. All the work was done by MRF.
I echo everyone's comments: Car feels amazing and it inspires a tremendous amount of confidence in the rear end. Only downside is the diff whine. I've been told its more pronounced on the DCT cars than the 6MT cars, which seems to be consistent with what I've seen. The 6MT guys seem to be the ones saying it's a nonissue and easily drowned out, whereas the DCT guys seem to be the ones hearing it the most. It's really only an issue for me at steady-state cruising above 65 mph. |
06-11-2015, 10:12 PM | #14 |
Rep 1,083
I have had Solid Aluminum Subframe Mounts and Powerflex Purple Diff Bushings for about 5 months now.
Since my car was supercharged, when I am cruising and then I apply full throttle, the rear would strut down prior to launch. The solid mounts minimized that delay. There's not much diff whine since I didn't do the solid diff mounts. The whine of the Supercharger definitely covers the whine of that.
06-11-2015, 10:32 PM | #15 | |
Rep 3,742
06-11-2015, 10:40 PM | #16 |
Rep 1,083
Yes they are street oriented as my car will most likely never see a track. On another note I also have the Rogue Front Tension Arm Bushing. Now the front feels so sharp and the steering freeplay is next to none.
06-12-2015, 12:27 PM | #18 | |
Rep 794
06-12-2015, 12:29 PM | #19 | |
Rep 6,771
Drives: 2016 BMW i8
I rode in Nick's car who has solid subframe and diff and it was too loud for me as well. So this could be a good solution for optimal performance.
06-12-2015, 12:30 PM | #20 |
Rep 5,498
The opinions in this thread about the NVH produced from the diff bushings truly shows how subjective things can be. I don't notice them anymore. If you have an aftermarket exhaust or listen to the radio, your most likely not going to notice the sound.
06-12-2015, 12:33 PM | #21 | |
Rep 794
06-12-2015, 12:36 PM | #22 |
Rep 794
You're right, its all very subjective, i'll make sure to keep that in mind. I don't mind sacrificing a little practicality for performance though so well see. I'd be surprised if I decided not to do them.
