European Auto Source
      05-21-2018, 02:05 PM   #1
kevin///mlee
kevin///mlee's Avatar
93
Drives: E90 M3, E30 M3
2008 M3 - Intermittent low beam issues
My new-to-me E90 M3 is having intermittent low beam issues. About 50% of the time, the passenger low beam will not fire when I turn on the headlights. The other 50% of the time they work perfectly fine.
If they do fail to fire, I get the warning on the dash saying there is a low-beam malfunction. Sometimes I can "recover" by toggling the lights on/off a few times, but this is not fool-proof. There have been cases where they refuse to fire at all and I have to drive with 1 light out. In general, once they are on they stay on for the remainder of the drive, however I think once the passenger light actually turned off mid-drive when it was working fine.
There is no discoloration or dimness in the light output when they are working.
Has anyone experienced this in their car before?
Akrapovic | AngeliBright | APEX | Hankook | IND | JRZ RS1 | Macht Schnell | Mode Carbon | Vorsteiner
      05-21-2018, 04:20 PM   #2
amrazM
resident Genius
Drives: like a granny.
Send a message via AIM to amrazM
Rather than throw money at the issue you can try swapping the ballast first from the right side or if you know someone with an ista you can run a test plan on the FRM2 and check for any shorts.
      05-21-2018, 04:20 PM   #3
XKxRome0ox
e90noob
Drives: '08 E90 M3
did you check the connections?
next would be to check the ballast
ballasts do fail over time
2008 E90 M3
      05-21-2018, 05:42 PM   #4
azndrunk74
Drives: E92 SG/FR M3
bulb/ballast failing or on it's way out. swap them from side to side and see if the failure follows (bulb or ballast).
2009 E92 | DCT | Space Grey | Ext. Fox Red | OG Volk TE37 | ACM Mod | EAS 80mm Tips | Forcewerkz Skirts | Varis Lower Diffuser | MCarbon GT4 | M Perf. Spoiler | M Perf. V2 Electric Wheel | M Perf. CF Caps | Pedal Haus DCT Pedal & Paddles | Edition Grills & Gills | GTS DCT Tune | Red Brembo 380/380 | KWV3 | RDSport Front Sway | BW Sway Links | RE Toe Links | ECS rear arms | Bayoptiks DTM Headlights | BE Bearings | ARP Bolts | BW Track Mounts | ESS 625 | ACM P3 Gauge | BW X-Pipe | AFD Kit on E50 | 554whp/373wtq@7psi
      05-22-2018, 11:37 PM   #5
kevin///mlee
93
I checked the connections and swapped the driver/passenger bulbs today. I only got to go on a quick test drive but both lights were working afterwards. I will report back if/when one of them fails so I should be able to narrow down if it's a bulb issue or ballast issue.
Thanks all for the suggestions!
      05-23-2018, 12:21 AM   #6
E46M3forRay
GŁdentyte
E46M3forRay's Avatar
Drives: E90 M3 and E90 335i
I donít know anything about lights but welcome back Kevin
CURRENT - Alpine Weiss E90 M3 6MT | CURRENT - 5th Gen 4Runner Limited 4wd | SOLD - E90 335i | SOLD - Toyota FJ Cruiser AT | SOLD - E46 M3 Vert 6MT | SOLD - E39 Dinan M5 6MT | SOLD - B5 S4 bi-turbo 6MT | SOLD - EVO VIII turbo 6MT | SOLD - Integra GSR turbo 5MT
      06-18-2018, 05:42 PM   #7
kevin///mlee
93
After I swapped the bulbs left to right, the issue seemed to have disappeared for a few of weeks, but I just got a low beam error again this week. The issue seems to have followed the bulbs (used to occur on the right side, now occurs on left). Looks like I'll be ordering some new bulbs here shortly!
      06-18-2018, 06:45 PM   #8
timothy2001
timothy2001's Avatar
Drives: 2011 E92 M3 6MT ZCP
2017 Mercedes E300  [0.00]
2011 M3 E92  [0.00]
Had a similar issue and it was caused by the previous owners non OEM lights. Went back to oem and that solved the problem.
      06-18-2018, 08:33 PM   #9
kevin///mlee
93
Yup, same here. Dealing with non-OEM bulbs from PO. Thanks for confirming OEM bulbs fixed the issue for you
Search this Thread:
Advanced Search
