02-03-2020, 10:47 AM | #1 |
just another M3
514
Rep 1,151
I worked on replacing my clutch and flywheel this weekend and I after all the work car wont start. Just cranks and pops.
Right away I thought to check the the crank position sensor since it’s located on the transmission, it was working (ordered another just in case and its on its way) But soon after I remembered I don't recall if I installed the flywheel in the same position as the original one. That being said, no I don't know what the original position is anymore since I cranked the motor several times. I searched for hours and look through many different manual (newtis.info, e-manualsonline etc) none of them reference about flywheel timing or show in the reinstall instruction about a position. Does anyone have in information of experience with this. Much appreciated.
///M3... Don't want more power, Just want it to turn sharper one step closer each time. -Ohlins TTX Raceline, PolePostions seats, Akrapovic EVO, ARC-8, 1/2 Cage, Seat Delete, Stoptech BBK, solid Subframe and diff bushing, spherical bearing on everything.
02-03-2020, 11:10 AM | #2 |
mTekMods
2143
Rep 2,902
The flywheel just goes back into the dowels, I've never aligned a flywheel a certain way. Did you check resistance across the CPS?
02-03-2020, 02:33 PM | #3 | |
just another M3
514
Rep 1,151
Thanks
02-03-2020, 11:54 PM | #4 |
Rep 191
You likely misaligned the flywheel. The dowel on the crank lines up with a specific position on the flywheel. If it is not in that position then the crank sensor thinks TDC is in a different position than it really is...that's why it doesn't start. Seen this happen far too many times over the years.
tlrid3r513.50 |
02-04-2020, 12:09 AM | #5 | |
just another M3
514
Rep 1,151
I guess I'll have to remove the trans and flywheel again. Only thing I need to sort out is how to remove a brand new clutch without affecting the self adjustment part.
02-04-2020, 06:47 AM | #6 | |
Rep 2,907
Drives: 2011 E93 M3
-Dropped the flywheel or damaged the reluctor ring. -Misaligned the dowel sleeve. -Left other wires disconnected or became damaged. You'll need the special BMW centering ring and lock tool for the Self Adjusting Clutch (SAC). There is no other way to safely remove the clutch without affecting the adjustment. If you remove the clutch without doing so, you'll need a different SAC clamping fixture tool to depress the pressure plate and reset the adjustment, then use the holding ring tool to hold that position until the clutch is installed. Another gotcha on the tooling- Not all clamping fixtures are compatible with the updated clutch diameter even though they say they are. Especially the Chinese tools. |
tlrid3r513.50 |
02-04-2020, 09:41 AM | #7 | ||
just another M3
514
Rep 1,151
I'll be removing and check on everything.
02-04-2020, 09:53 AM | #8 |
Rep 2,907
Drives: 2011 E93 M3
Pressing in the clutch isn't resetting it. You need to press it in and use the holding ring tool to rotate the three SAC fingers simultaneously. I don't know how you'd manage that without the tools so I'll just remind you that pressure must be applied evenly or you'll damage the pressure plate and/or SAC components.
I highly suggest using the right tools or you'll end up pulling the transmission a third time to fix disengagement issues, or after 10k miles because the clutch wore out prematurely. Happy wrenching |
msan402.50 |
02-04-2020, 10:41 AM | #9 | |
just another M3
514
Rep 1,151
I used a harbor press to press with a still disc to apply even pressure. I did this on the old clutch just to see how it works.
02-04-2020, 11:17 AM | #11 | |
just another M3
514
Rep 1,151
I'll update my finding
02-04-2020, 12:06 PM | #12 |
Rep 1,881
all the SAC equipped bmw that i have done a clutch service on, had a pressure plate alignment tool attached, that is not removed until the assembly is installed. Are there additional tools that are required beyond this for new parts replacement?
02-04-2020, 12:21 PM | #13 |
just another M3
514
Rep 1,151
No you don't need more tools, my question is for after the initial install how do you remove and reinstall with out losing the self adjustment
02-04-2020, 06:56 PM | #14 |
mTekMods
2143
Rep 2,902
02-06-2020, 06:14 AM | #15 | |
Rep 1,893
That said, he is a professional and likely not given to half-ass solutions of the sort sometimes employed by hobbyists (like myself). So here's my $0.02 I've used two non-approved and potentially dangerous solutions to this problem on N54 and S65 engines, with good results thus far: Since you very recently replaced the clutch pressure plate, you may still have the trefoil-shaped locking ring that the plate should have been shipped with - the one you remove after bolting the plate up to the flywheel. Remove the plate from the flywheel and don't worry about losing the adjustment. Then center the locking plate onto the fingers of the diaphragm spring and use it to position an 8" Harbor Freight 3-Jawed gear puller (about $17). Compress the diaphragm to the point where the clutch plate is retracted more or less flush with the housing. You may have to adjust the amount of compression but at some point it will become relatively easy to rotate the self-adjustment ring by hand or small screwdriver. Once those three little springs are compressed, you can rotate the locking ring into place. The latter will require tapping with a punch and small hammer because it is under pressure. Now you've restored the pressure plate to its original condition and you can remove the puller. The process can also be completed if you don't have the original locking ring. However, in this case, you need to place an appropriately sized washer or metal disk on the diaphragm spring to compress it and you need to keep the 3-jawed puller in placed while you bolt the pressure plate to the flywheel. If you are careful about the placement of the jaws of the puller, this can be accomplished. Not necessarily recommending that you do this, just putting it out there. If I could have sourced a good SAC tool for what I considered a reasonable price, I would have done it that way. At the time, I didn't find any Chinese tools. Although I note Deansbimmer's caution that the Chinese tools may not fit correctly, for $75-$100 I'll probably give the Ebay tools a try if there is a next time. Edit: perhaps needless to say, you need the right kind of alignment tool to center the disk, one that doesn't stick out too far since the center of the diaphragm is covered with the locking plate/washer but one with a threaded bolt hole to allow removal after the locking plate is taken off. Last edited by dpaul; 02-06-2020 at 07:13 AM.. |
deansbimmer3750.50 tlrid3r513.50 |
02-06-2020, 09:15 AM | #16 | ||
just another M3
514
Rep 1,151
Thanks again
02-06-2020, 07:35 PM | #17 |
Rep 787
I'm interested on the results.
Mine is 40k miles, some day - I hope it take a long time - I'm gonna need to do it. Actually, I was wondering if it would be good to use a lighter flywheel, in order to make the RPM more easy to go up and down, and make faster gear shifts (we are talking about manual transmission, right?). If it is possible, what would be the cons of that change? |
02-07-2020, 08:30 AM | #18 | |
Rep 2,907
Drives: 2011 E93 M3
02-07-2020, 03:59 PM | #19 | |||||
just another M3
514
Rep 1,151
Yeah. My car has 110k miles. Finally the clutch was on its way out. Stick with stock. I personally think oem is the best on this scenario. To me lighter flywheel on low torque engine doesn't help much.
02-07-2020, 08:05 PM | #20 | ||||||
Rep 2,138
Drives: 2011 E92 M3
02-10-2020, 12:41 AM | #21 | |||||||
just another M3
514
Rep 1,151
Car runs. Clutch feel great. Well lesson learned to pay full attention. Just because it assembled well doesn't mean it's right. I was rushing the job and that cost me double the time.
02-10-2020, 08:26 AM | #22 | |
Rep 2,907
Drives: 2011 E93 M3
