      03-06-2016, 05:19 PM   #1
Godchild14
Godchild14's Avatar
52
Drives: 2013 E92 M3
E92 M3 Transmission problem
Has anyone ever saw this message before I don't know if it's my sensor or I need to bring it to the dealer
R3DVelvetM3
      03-07-2016, 08:06 AM   #2
BrewRifle
BrewRifle's Avatar
Drives: 2011 MCB E92 M3
2011 BMW M3  [7.56]
2013 BMW X3 35i  [0.00]
2009 BMW 135i  [8.00]
take it to the dealer if you're under warranty and I'd look at purchasing a device to pull codes for easier troubleshooting.
2011 Monte Carlo Blue E92 ///M3 - ESS VT2-625
      03-07-2016, 08:34 AM   #3
Godchild14
Godchild14's Avatar
52
Drives: 2013 E92 M3
Thanks yeah the car is still under warranty
R3DVelvetM3
      03-24-2016, 10:09 AM   #4
Godchild14
Godchild14's Avatar
52
Drives: 2013 E92 M3
So finally I got my car back yesterday the cause of the transmission malfunction Light due to TCX CASE MECHATRONICS 84290 REPLACE SHAFT SEAL and REPLACE MECHATRONICS, REPLACE O-RING, SNAP RING, HYDRAULIC COVER, COUNTERSUNK SCREW
And it also fix the reason why the message was coming up when I put the car Neutral and the message read car not in Parking Position so it was about $9000 worth of work done so make sure you have warranty for your M3
R3DVelvetM3
      03-24-2016, 12:52 PM   #5
anerbe
Drives: Red E90M 6MT
:-o
      03-26-2016, 02:25 AM   #6
twinpuller
Drives: 08 M3 Sedan
wow $9k!
      03-26-2016, 02:57 AM   #7
vsix
vsix's Avatar
Drives: M3 E92 sold, M4 F82
Same here, look up on Carly OBD2 WIFI dongle ( video is in my sig )
Almost everyone on here uses it.
It has a truck load of features, operated by your smart phone.
I would even get it before I drive the car to the dealer.
If you are in doubt whats the issue with your car, send over the Carly app of your iphone an help request and certified mechanics in munich will take care of you and point out the issue for free ( after you purchased the app and dongle ) of your transmission.
If your down for a purchase, be aware that the Carly OBD2 WIFI reader will be available by the end of march.
Dont forget to use the 5 Euro coupon code, mentioned in my sig. No need for you to pay more then anyone of us
With Carly you can:
Read & Clear codes
Code your car
Health record of your car
Oil value read out, no more overfilling
VIN CHECK ( stolen car checkup )
ODO CHECK ( real mile checkup )
Pre owner driving habbit check
In depth parameter diagnoses
Session log life parameters
Mechanical advice on car related issues ( in app feature )
over the wire, so to say for free
Battery registration
Hope I could help you with my information and wish you good luck OP!
