02-12-2016, 10:29 AM | #1 |
Rep 64
Best fuel/octane for SC M3
Hey guys,
Recentley picked up an ESS 625 Kit. Will be attending the upcoming Shift S3ctor airstrip attack and was just wondering what fuel/octance has given the best gains? As coming back from an FBO F82, I used to run a blend with E85. I have heard some people have been blending about 2 gallons of e85 in with a full tank of pump gas however Idk how well it works with the E9X platform.... So my question would be, does the ecu only read up to a certain amount of octane due to the paramaters set on the ecu? Would you guys suggest. MS109 straight or mixed with pump gas? Or 100oct straight or mixed? Or 2 Gallons of e85 mixed in with a full tank of pump gas? Your input will be greatly appreicated, thank you! |
02-12-2016, 12:49 PM | #2 |
Rep 6,771
Drives: 2016 BMW i8
Hey Nick bring your M3 to NoFlyZone in April. I'll run pump 91 with 2.5 gallons of e85 (e25 mix) and you run MS109 and lets see what happens.
02-12-2016, 01:36 PM | #3 |
Rep 7,542
More octane is not always better. There's a point of diminished returns.
02-12-2016, 02:51 PM | #4 |
Rep 1,673
Between your 3 options I would run straight 100. The motorsport 101 is the easiest option but you could always mix down the 109. If money is not a object you will be better off staying away from e85. Remember though if you mix down 109 with pump 93 to 101 it still will not make as much power as the pure 101
Electronics Junkie, Engine Builder.
02-12-2016, 03:33 PM | #5 | |
Rep 6,771
Drives: 2016 BMW i8
02-12-2016, 04:12 PM | #6 |
Rep 594
02-13-2016, 09:53 AM | #9 |
Rep 1,673
I can see that, 109 is too much octane for the timing map and when you mix 91 in it the oxygen content is cut way down. You should try straight 101 that is oxygenated and see what it does. Thats why I said a cut down 109 is not as good as the straight 101.
02-13-2016, 10:41 AM | #10 |
Rep 64
I have messed with e85 before in the past. In the M4 definitely had more gains with a blend of e85 with pump gas than straight vp101! vp 101 seems to be the safest and the most used on sc platform. BUT I will experiment on the dyno here shortly, just want the most gains however want them safely!
02-13-2016, 10:42 AM | #11 |
Rep 64
Thanks man, 101 seems like the most used. Will definitely try that first!
02-13-2016, 10:44 AM | #12 |
Rep 64
02-13-2016, 11:09 AM | #13 |
Rep 10,616
You are tuned for 91 or 93. Your timing may not always hit the target and more octane will help it hit the target more often, but more octane will not change the target. Only the a new tune can change the target.
02-13-2016, 02:49 PM | #14 | |
Rep 6,771
Drives: 2016 BMW i8
Would you think the straight 101 could improve upon the power that 91/e85 mix = E25 provides? On my 991TTS I'm tuning it Wednesday (otherwise stock) and GIAC is telling me that I can go as low as E30 with full timing on their race map which otherwise needs straight 100+ octane or higher. If true E is unreal.
02-14-2016, 06:05 PM | #16 | |
Rep 6,771
Drives: 2016 BMW i8
Too much e85 would exceed the fuel system limit, so I make sure that I run between 2 and 2.5 gallons per tank. Our pump 91 in Cali has around e10 so that mixes to about e25.
03-01-2016, 06:55 AM | #17 | |
Rep 1,385
2011 E90m3 ESS G2, active auto x pipe, RK FULL E85, DD
2015 X5M Bootmod3, Downpipes, Mineral white-The wifes DD 1994 300zx 2jz Swapped slicktop- The toy/track car |
03-01-2016, 07:27 AM | #18 | ||
Rep 6,771
Drives: 2016 BMW i8
03-01-2016, 08:46 AM | #19 |
Rep 1,385
yeah it's amazing how much you pit up just taking off a bit of fuel. lol I actually just got a fuel pump error last night. likley the fuel pump controler but I'm going to use my warranty to have them both replaced. then maybe I will contenplate running a lil e again.
03-02-2016, 11:54 PM | #20 |
Rep 7,542
Shouldn't be running leaner with e85 after adaptations take place. A targeted lambda will be met regardless of the fuel type. Putting e85 in just means that the fuel trims will be higher to reach the target.
03-03-2016, 03:17 AM | #21 |
Rep 109
Whatever fuel you use, have someone who has a proven track record (like Mike) do a tune for you. Then stick to that fuel; you'd be surprised how much of a change in ideal timing and fuel use you will see from different fuels. Good tuners can be more aggressive with timing if they know the customer will be consistent with the fuel their using. Otherwise they have to retard timing and knock thresholds lower to be safe.
03-03-2016, 07:19 AM | #22 |
Rep 1,385
agreed if the car that is doing it has a healthy pump. It's still just a risk with the fuel system already being closer to it's limit on the a 650kit. Has anyone had any success with a after market pump like a a walbo 450 e85 pump? With e9x sysem altering voltage to the pump to get more out of them I wonder how the pump would react to it. I know my Z I had to bypass my fuel pump module to prevent the pump from burning up the controller.
