09-15-2015, 06:20 PM | #1 |
Rep 2,319
ACM | Gintani Cat Delete X-Pipe
Location is key when adding the "X" for the X-Pipe. Placing it closer to the engine allows the gases to cross earlier to give it more room for gas flow. These X-Pipes are built in the USA, beautifully hand TIG welded in house in California using only US 304 Stainless Steel. This system is a complete bolt-on; no cutting, welding or fabricating necessary.
Please note that by installing the X-Pipe, it is recommended to have an ECU tune for even higher power gainsand the removal of the 'check engine light' warning caused by the changes (higher flow rates) detected by the O2 sensors. *For off-road use only Gintani X-Pipe - $2,000 2 Resonators add - $0 4 Resonators add - $195 High flow cats add - $495 |
05-16-2016, 11:40 AM | #6 |
Rep 494
Drives: BMW 2011 M3
what does 4 Resonators do?
2011 M3 Coupe,Jerez Black,DCT,EDC,DSC 2010 X5 30i Black |
05-16-2016, 12:50 PM | #7 |
Rep 2,319
