06-29-2015, 11:05 AM | #1 |
Rep 650
Add oil
I have had this 2011 E90 M3 since March 2015. Oil change was done this spring about 4000 km ago. I drive the car like it was meant to, waiting for the car to be warmed up and then flooring the gas pedal when I feel like seeing some shift lights...
The oil was on the top mark at oil change, then about 2000km in, it went about halfway down, and now, at 4000km post oil change, I got the add 1L oil message. I added 750ml and went for a drive. Back at the top mark.... I know some of these cars drink a little oil... I'm just curious as to if my consumption is normal or excessive. As a side note, it seems my oil level dropped both times (to the half mark and the bottom mark) after doing some spirited driving... Is that pure coincidence?
Today's gains far outweigh tomorrow's losses.
06-29-2015, 11:29 AM | #2 |
Rep 979
The computerized dipstick is notoriously finicky. Its known to report incorrectly. Chances are you were never at max fill, just about 1/4 from max and then when the system caught up with your mileage and your top off you are more likely where you really are oil wise.
06-29-2015, 02:53 PM | #3 |
Rep 393
Drives: ///M3
Keep monitoring and see if in another 2000km - it drops again.
I just got my M3 and have put about 2500km so far, haven't experienced any consumption yet (1 track day at Mosport too - oil was changed prior to the track event). |
06-29-2015, 02:59 PM | #4 |
Rep 11,891
your consumption rates seems normal to me, especially since you implied you drive in the high rpm range all the time. I assume you're using 10-60...
In 3-months and 3000 miles, I've consumed about 1.25 bottles of oil, and I'm using 0-40
22 Phytonic/Coffee X5 45e (CoVID-free)
08 Speed Yellow 911 GT3 Sharkwerks 12 AW/Cinnamon X5d Sports Pkg (retired) 14 AW/Beige M6GC ZCP, MPE, V2 steering wheel, vorsteiner (retired) 08 SSII/Black E90 M3 (retired) |
06-29-2015, 03:04 PM | #5 |
Rep 560
Mine is bizarre as well. I'm usually 1 or 2 notches below the recommended max. Been putting in 250ml at a time, and resetting it, and yet it doesn't detect the added oil.
06-29-2015, 04:17 PM | #6 | |
Rep 11,891
Stop adding oil, if you're just 1 or 2 notches below max, you're at danger of overfilling if you keep adding at this point. Remember, that level indicator tells you the level at the final bottle level, not the overall oil system level. Given the time it takes for the indicator to re-adjust, your method is likely going to result in an overfill, which will cause damage and is a headache to correct. Plus, at your current level and anywhere in between the min and max line, the system is not "low on oil".
08 Speed Yellow 911 GT3 Sharkwerks 12 AW/Cinnamon X5d Sports Pkg (retired) 14 AW/Beige M6GC ZCP, MPE, V2 steering wheel, vorsteiner (retired) 08 SSII/Black E90 M3 (retired) Last edited by Flying Ace; 06-29-2015 at 04:27 PM.. |
06-30-2015, 12:45 AM | #7 | ||
Rep 298
2008 ///M3 - Dinan Intake & Exhaust |
06-30-2015, 08:03 AM | #8 | |||
Rep 650
Funny thought that the book says add 1 qt, the indicator says add 1L, and I added 750ml to make it full... Three different quantities here. Goes to show you the electronic dipstick is notoriously inaccurate.
06-30-2015, 08:30 AM | #9 |
Rep 117
I find I never have to add oil in between changes. ~7000km. I'm at 5000km now and haven't had to add anything? I get worried thinking my virtual dipstick is broken.
OP, do you know the OG owner of the vehicle? do you know if a full break in was done? http://www.mototuneusa.com/break_in_secrets.htm. I hear other forums say seals weren't broken in properly at break in period. |
07-01-2015, 09:02 AM | #10 | |
Rep 560
07-03-2015, 04:44 AM | #11 | |
Rep 7,091
I wouldn't worry. Same here never added a drop between 8000km changes, meter stays glued on top. Clearly quite big differences between engines oil consumption. Me, I don't mind having one consuming very little...☺ |
07-13-2015, 12:52 AM | #12 | |
Rep 916
07-19-2015, 10:14 AM | #13 |
Rep 924
I just changed my oil completely yesterday. I put in 9 liters of the new BMW M recommended oil. My system still states my oil is half. How long does it take to recognize the new oil?
07-21-2015, 05:16 PM | #14 |
Rep 54
Drives: 2003 E46 M3
Sounds about right. Mine does the same. Just run it and when it has consumed enough to ask for it, add a quart/litre.
2003 E46 M3 Carbon Black
07-22-2015, 04:28 PM | #15 |
Rep 364
i had low oil warning a few weeks ago. didnt get around to going into the dealership until this past weekend. (I only drive my car on the weekends) When i said i was in to buy some oil, they offered to top it off complimentary.
After they brought the car around, i noticed the meter read full. I'm assuming that's normal. The car didnt feel any different, so i don't think they overfilled. But the question I have is, how would they know how much to put in? Is it bad that it reads full? |
07-22-2015, 08:35 PM | #16 | |
Rep 650
So if yours shows full and in the next couple of days, it still shows full once you be started your car a few times, I would assume you're ok...
07-24-2015, 03:54 AM | #17 | |
Rep 924
I thought we would need 9.5 liters including the filter... I am confused... |
07-24-2015, 04:39 AM | #18 |
Rep 7,091
Believe the complete system is 8.8 liter. I'd be careful adding more than that mate.
07-24-2015, 12:27 PM | #19 | |
Rep 924
07-24-2015, 05:18 PM | #20 |
Rep 54
Drives: 2003 E46 M3
Does it really matter? Like with a manual dipstick it's a minimum to maximum scale. As long as the reading is somewhere between the two, you're good to go.
09-20-2015, 07:27 AM | #21 | |
Rep 650
About 300km-400km after it had gone down to the half full mark (4300km-4400km after adding 750ml), I was driving calmly when I decided to check the oil level, as I often do... The level had gone back to FULL... !?! I know the electronic dipstick isn't too accurate, but going back to FULL? Hope my block isn't cracked and coolant is in the oil!! (ya I'd know with all the blue smoke I guess!) I'm doing my 8000km oil change this week, so I'm not worried or bothered, but I am slightly confused! Anyone have a similar story where the car gives them a "free oil fill up"?
09-20-2015, 01:58 PM | #22 |
Stop the hate, get a V8
3850
Rep 8,625
Overfill is going to be more dangerous than a slight underfill.
Overfill can cause frothing and other odd things to happen. A slight underfill will have an impact on the engine's ability to shed heat into the oil, and perhaps have some negative consequences on long-term contaminant suspension. Note that I am talking about a *slight* underfill, not an egregious one where only half of the necessary oil is added.
Past: 2011.5 M3 sedan ZCP |
