05-31-2008, 02:22 PM | #1 |
Rep 1,430
Operating Temperature Variation
I've noticed that under regular driving, even in the heat, my car will stay just below 210. On the track, however, it was a little above 210 toward the end of each session. Has anyone noticed this when running the car hard? I assume it's normal, but just wanted to make sure.
06-02-2008, 03:04 PM | #2 |
Rep 1,430
No one? It happened yesterday when I was just driving hard. Air temp was ~87.
06-02-2008, 04:11 PM | #3 |
Rep 4,145
Yes, this will happen. As long as it doesn't go to the end of the dial you're ok. If that happens, pull over before something bends/breaks. BTW, the fact that it only went a little above mid-temp on the track speaks well of the car.
2017 F80 YMB.
06-02-2008, 04:13 PM | #4 |
Rep 1,430
My E46 never moved at all, even on track.
06-02-2008, 05:13 PM | #5 |
Rep 4,145
Mine would. Driving hard in the summer it would go to about where you said yours was -- just high of center, maybe a tad bit higher.
2017 F80 YMB.
06-02-2008, 09:50 PM | #6 |
Rep 8,033
I see slight variations in my oil temp depending on what i'm doing the car and what it's doing to me. I'm glad they gave us a functioning gauge.
06-02-2008, 10:02 PM | #7 |
Rep 492
yep, e46 gauge never moves, not sure it's connected to anything.
E90 M3 Sedan
06-02-2008, 10:38 PM | #8 |
Rep 666
I'm still in the break-in phase but my gauge always goes JUST slightly over the midpoint with my normal everyday driving
2008 E92///M3 - | Alpine White/Fox Red Extended Novillo | Technology | Premium | Cold | Mods: | 19" Avante Garde | Macht Schnell Filter | RPi Scoops | Rogue SSK | MS Spacers | ACM Test Pipes | ESS Tune | Remus Race | LUX V4 Angels | KW V3 | |
06-03-2008, 06:54 AM | #10 |
Interlagos FTW!
Rep 167
06-03-2008, 09:22 AM | #11 |
Rep 4,145
What year was your E46? Mine was 2002 and definitely moved. It started near the left end when I would start the car up after sitting a while. As the engine warmed up the temp would slowly rise until it would settle near center when it was finally up to temperature. I'd used it to tell when I could start increasing revs, basically a more conservative check on the tach yellow line.
2017 F80 YMB.
06-03-2008, 09:48 AM | #12 | |
Rep 3,303
"...it's not about the money and not about the brand of the car, it's about handling,performance and passion......And that, no other car has all together like an M3........when you talk about the most complete car the M is invincible." --Tony Kanaan. |
06-03-2008, 10:09 AM | #13 | |
Rep 4,145
I had a '94 Miata which had a real working oil pressure gauge. But a year or two later they started putting in "dummy" gauges. When the car was started the needle would pop up to center and stay there; no movement of the needle and no real indication of oil pressure. Why they did this is beyond me. So, I was thinking that maybe BMW might have done this on certain model years. I know it's a stretch. I'll go away now.
2017 F80 YMB.
06-03-2008, 03:48 PM | #14 |
Rep 1,430
No, my E46 gauge moved, but never like the E92 does. Thank God they didn't put a dummy in because I had to have my thermostat replaced in the E46. I'm guessing the reason the M3 moves so much is because it's a lot more high strung than my 325 was and the tolerances are a lot closer so it's more vulnerable to a change in air temp.
