09-09-2015, 11:06 AM | #1 |
Ultimate driving machine
27
Rep 230
Leak from Driver side Footwell
Hello,
As most of us on this forum, i enjoy attacking on and off ramps, and definitely push the car on there a bit. I have noticed starting this summer (it has happened twice) that there is some liquid that starts dripping/seeping out of the Drivers side footwell underneath the center instrument panel. It is a cold liquid. And i have only felt a few drops both times while cornering. The carpet is not very moist. I can't put my finger on what exactly it could be. Is it some condensation due to the AC on hot summer days, anyone else experienced this? Thanks!
09 E90 M3: JB, DCT
07 e92 328i, montego blue, saddle brown, poplar wood trim, premium, sport, cold weather, logic7, and navigation.---SOLD 2/13. |
09-09-2015, 11:12 AM | #2 |
Bad Lieutenant
232
Rep 3,517
Maybe your evaporator drains are clogged. They are located under the vehicle. Have you ever had the windshield replaced?
09-09-2015, 11:14 AM | #3 |
27
Rep 230
Yes, i had my windshield replaced last year, due to a rock chip. Thanks for the quick reply thekurgan
09 E90 M3: JB, DCT
09-09-2015, 11:39 AM | #4 |
Bad Lieutenant
232
Rep 3,517
The cowl cover may not be attached properly, and if it is, you may want to remove it to check the windshield seal. Water leaking from the seals or the door vapor barriers is more common then near the console so I suspect the windshield.
09-09-2015, 11:52 AM | #5 | |
Rep 330
I just replaced the lower windshield cowl... took me about 2 hours going slow. It is definitely the most involved lower cowl I've ever done. Compared to doing it on an Acura MDX that took all of 15 minutes. If you want any tips on replacement let me know. Part is about $85. |
09-10-2015, 08:56 AM | #6 |
27
Rep 230
Thanks for the info guys. I will look into that, and hopefully my problem will be solved.
09 E90 M3: JB, DCT
09-28-2015, 02:43 PM | #7 |
27
Rep 230
So, cowl cover looks really good, had my windshield re-installed. Now my AC no longer blows cold air....could it be that my evaporators are clogged and i need to unclog or is this more of an AC Evap replacement issue?
09 E90 M3: JB, DCT
09-28-2015, 03:42 PM | #8 | |
Rep 7,109
Thanks |
09-28-2015, 04:11 PM | #9 | |
Rep 330
Optimally the seal on the top of the cowl that sits on top of the glass and that you can see should also form a nice tight seal so 99% of the water gets pushed to the sides and never has to touch that underside cowl seal. The seal on the top of my cowl was nice and tight against the glass until they replaced my windshield. When I got it back it was no longer tight and there was an obvious gap that all of the water would flow under/into. This bothered me for three reasons: 1. It looked horrible with a gap and 2. It made me concerned that they potentially didn't get a good seal on the underside of the cowl and 3. I don't like not being able to see on the underside of the cowl so if water does get past the underside seal it will be too late and end up in a bunch of bad places. I should have taken a bunch of pictures when I replaced the cowl to show what the underside seal situation looks like. It is a bit tricky to install/re-install if removed and I have trust issues with other people touching my car. They seems to always mess something up or they don't do it perfectly. Also, it was only a $85 part (cheap I thought considering it is a large part for a M car) and while a bit annoying to install, I sort of enjoy DIY jobs. Like I mentioned, if anyone decides to tackle this, send me a PM and I can share a few tips. Takes about 1-2 hours. |
09-29-2015, 04:03 AM | #10 | |
Rep 7,109
again the guys doing the job was really careful, to the point they sent me Pictures from the process without being asked etc, but yes the cowl isn't completely tight on but still look good. I'll have Another look at this. Are you sealing with silicon or something here..? Cheers |
09-29-2015, 11:28 AM | #11 | |
Rep 330
