  TireRack
      10-16-2023, 09:04 AM   #1
exVtekGuy
Drives: none yet
wheel bolt option?
Hi guys
I wanted to get a new set of wheel bolt and trying to figure out what's the best. I do want to track some next year. Can you guys make recommendation? OEM is $5 a piece. ECS has their own which is 10.9 grade for $3..
      10-30-2023, 09:11 AM   #2
MineralWhiteF80
Dont listen to me
Drives: F82, E92 M3, G30 M550i, E46
Realistically, both OEM and ECS should be fine.
But the most important question is: Is it worth saving a mere 40 dollars on what is arguably one of the most important safety items on the car?
I would be buying OEM BMW or a tested motorsport version of a wheel bolt or wheel stud/nut kit. Not worth crashing your car, other's cars, or killing yourself when your cheap wheel bolts shear off.
Instagram: @thatwhitem4
      10-30-2023, 11:30 AM   #3
TboneS54
YNWA
TboneS54's Avatar
Drives: 2004 M3 6spd & 2011 M3 DCT
instead of chinese made aftermarket, you can get european made OEM versions (rein or febi iirc) to save $ from Genuine BMW.
Found it:
https://www.fcpeuro.com/products/bmw...YaAoRTEALw_wcB
Half price
/// 2004 Silvergrey M3 · Coupe · 6MT · Slicktop · zero options
/// 2011 Jerez/Bamboo E90 M3 · DCT · Slicktop · IG: @na.s54
      11-05-2023, 11:42 AM   #4
nyc_dude
nyc_dude's Avatar
Drives: 09 //M3 e90 Interlagos Blue
If you get spacers, they come with longer wheel studs included. Look into the Future Classics Spacers from IND.
Cheers
      12-10-2023, 12:51 AM   #5
M3SQRD
M3SQRD's Avatar
2164
Drives: E92 M3,G20 330ix,F22 240iX,F82
If you’re getting stock length lug bolts then definitely BMW OEM. If you’re getting spacers make sure to ask for the manufacturer and material strength. I’ve used Turner wheel spacers for at least a decade and have had zero issues with their longer lug bolts on the street and track.
