10-03-2011, 02:41 PM | #1 |
USAF/ Veteran/ F-16 Crew Chief
59
Rep 384
Drives: 2018 Atlantis Blue Metallic M4
*Help!* Metal Popping Noise (KWv3 Coilovers Installed)
It's been about a little over a month trying to find were this noise is coming from and narrowed it down to the rear drivers side shock strut area. The problem is it fine when driven on smooth roads or highways but the very first minute I get onto a main road that is somewhat bumpy, it has a loud popping noise as if the nut on top shock strut is loose and the strut itself travels up and hits the subframe or something to that effect. I got the car jacked up and took the trunk lining out and the wheel off and nothing is damaged or show signs of cracking, bending, buckling, chaffing, rubbing or gouging. All the nuts and bolts are present and accounted for and they are all tight! Does anyone know what could be causing this?
BTW, my car is not slammed compared to some M3's and it is only located on the drivers rear wheel well area. I thought I may have been riding on my bump stop but if that was the cause, wouldn't I be getting this noise from the other side as well??? WTF gives? For a quick reference, from the ground to my fender measures 26" on both sides in the rear. Thanks for the help! |
10-03-2011, 03:22 PM | #2 | |
Supreme Allied Commander
3847
Rep 54,376
Drives: F80 M3
Location: Santa Barbara, AP, Brembo, GIAC, Koni, Ohlins, Performance Friction, www.hpautosport.com
10-03-2011, 06:57 PM | #3 |
Rep 3,157
Yep! Harold is a great guy!
Past: Gintani stage3 M3, Cayman GTS present: Porsche 993RWB, 964RS America,996 cupcar, 964 turbo 3.6,Macan Turbo,997GT2,930 turbo,i3, MINI JCW |
10-04-2011, 12:23 AM | #4 |
78
Rep 684
I would uninstall and retorque the shock top nut and the shock bottom bolt on the camber arm.
Torque to: Top nut: 30 ft-lb Bottom bolt: 75 ft-lb GL!
10-04-2011, 12:32 AM | #5 |
59
Rep 384
Cool, Thanks! I will try that out and see if that fixes the problem. Any more help or ideas are appreciated...
10-04-2011, 12:56 AM | #6 |
Rep 2,736
Drives: 2008 E92 ///M3 Alpine White
Happened to me too. It's the top nut!
