06-25-2019, 11:28 AM | #1 |
Rep 548
Drives: 2011 E90 M3 ZCP
034Motorsports Subframe Inserts?
Hi all, has anyone used these? I spoke with someone at 034Motorsports and they confirmed that they will also fit the E9X M3!
https://store.034motorsport.com/bill...t-e9x-bmw.html |
06-25-2019, 11:52 AM | #2 |
Rep 6,734
I guess it might be a decent incremental step to reduce slop in the sub frame mounts - without the need to drop the entire rear sub frame. However I would recommend dropping it and installing solid mounts if you want actual detectable improvement.
'23 X7
06-25-2019, 12:06 PM | #3 |
Rep 548
Agreed, was just trying to avoid all that work. It sucks because I'm now realizing these won't fit the E9X M3. Looks like it's non-M only. :-(
06-26-2019, 06:15 PM | #4 |
Rep 2,824
I looked into it a year ago and they told me they would not fit the M3 models.
I thought it would be worthwhile if they were significantly easier/quicker to install. If comparable labor, go straight to solid for sure. |
06-26-2019, 06:47 PM | #5 |
Rep 548
I spoke with a few people and confirmed they won’t work. The M3 bushing doesn’t have a void like the non M3 bushings do (which these would fill to make them stiffer).
