10-10-2010, 09:49 AM | #1 |
Rep 225
For those who still undesided regarding basic mods (springs,spacers)
Hello,
I just started to slightly mod my M. Goal was to get most bang for the buck.... I went with HR springs and 15mm H&R spacers all around. Total in parts = $550 If installed at a shop appx. $200 - $400 in labor (my dealer would have charged me $900 for instalation ). I did it myself... Total labor = $0 Here ist a DIY for the springs, great write up..straight forward install: http://www.m3post.com/forums/showthread.php?t=183011 I'll give the springs 2 weeks to set before I have the wheel alignment done which is appx. $200 at the BMW dealer. The photos were taken right after the install, I'm sure the car will drop a little more after some time. The car/ photos will be boring for 99% of the forum since it is besides the springs and the spacers pretty much bone stock, however, for "starters" it may provides a good before and after view to help them decide whether or not install springs/spacers. The car's suspension feels with the H&R springs a little stiffer/firmer because of the higher spring rate of the aftermarket springs, it also seems like that the beam of the headlights is a little lower which very likely could be adjusted with the headlight level sensor, the right rear is rubbing a little bid (with 3 persons in the car going over rough roads), other than that, I did not recognize any other changes. All in all, I'm very happy with the spring/spacer combo...Imho it makes a big difference for $550. Alex |
10-10-2010, 10:37 AM | #2 |
Rep 9,034
Looks great.
Did you paint the hub or use some grease on the spacers? They can get stuck after only a few miles. Here's some info on the headlights adjustment after a suspension job, but it sounds like you got it right since the lights are low. http://www.m3post.com/forums/showthr...ght=headlights .
10-10-2010, 12:18 PM | #3 | |
Rep 225
thanks for your compliment, as said before, it's nothing special at all but the M3 looks bone stock already freaking good I put grease between the hub's and spacers and between the spacers and rims and a little bit on the tip of the bolt's. Before I took the leveling sensor off, I made a little sketch...if you look at the sensor leverage from the backside of the car, it must liik like a "C" and not like a mirrored "C". Alex |
10-11-2010, 12:32 AM | #4 |
Rep 1,508
No doubt. Much better. Congrats.
I am also running H&R sport springs but with 12mm spacers all around. I found that the 15mm spacers were causing excessive rubbing on the rear tires with the rearmost wheel well plastic liner.
Current: 2016 F80 M3 6-Speed | SO | AB XT1 | ZCP | M Performance Suspension | GC Camber Plates Previous: 2009 E90 M3 |
10-12-2010, 11:31 AM | #7 | |
Rep 225
It was rubbing on the inner bumper plastic-liner. I just shaved off the very tip of it, caulked it afterwards....no rubbing anymore Therefore 15mm spacers are duable with the posibility of small tweaking @ the bumper liner.... You may get lucky without doing anything, I only had to do it on the right side, the left side has enough clearance. Last edited by SchwarzerM3; 10-12-2010 at 09:29 PM.. |
10-12-2010, 11:33 AM | #8 |
Rep 225
