08-03-2020, 03:18 PM | #1 |
Rep 288
Hub Center Bore Questions - off by 0.5mm
I have a set of 19" wheels with a center bore of 73.1mm...OEM is 72.56mm.
I can't find 73.1 to 72.56mm hub centric rings anywhere except eBay. I bought them and they didn't fit. Do you think I will have issues running the wheels as is? Mainly concerned about damaging the hub or being dangerous. Appreciate all of the help!
22 Florett Silver SQ5
13 Silverstone II E92 M3 (Sold) 19 Shadow Black Shelby GT350 (Sold) 13 Mineral White E92 M3 (Sold) 11 Melbourne Red E92 M3 (Sold) |
08-03-2020, 03:46 PM | #2 |
///M Powered for Life
11493
Rep 10,331
You need a hub centric spacer to run those wheels. The weight of the car rests on the hub
08-03-2020, 03:48 PM | #3 |
Rep 3,988
Have the wheels bored out maybe?
74.1mm is a more common size because E39s came with that size, so you'll likely find hub rings easier.
08-03-2020, 05:56 PM | #4 | |
Rep 674
Ton of people race track and autox without hubcentric rings without issues. I had volks that werent and even cracked the spokes from autox stress |
08-04-2020, 07:02 PM | #6 |
Rep 288
Anyone else? Trying to find someone who will custom make plastic rings for me, as the aluminum ones keep bending in the mail...
08-06-2020, 01:58 PM | #7 |
Rep 674
0.5mm is such a small width no one will make that for you
Only option is to get custom spacers that match the hub bore and wheel bore Either way you are overthinking this |
6ixSpd6015.50 B8bydesign680.00 |
08-06-2020, 04:00 PM | #8 | |
Rep 2,354
Or find wheels that have a hub bore that it correct. GL!
BSM ///M2cs, 6spd
08-07-2020, 10:07 AM | #10 |
Rep 1,591
For driving on the street, a non hub-centric wheel will be okay. For track use I'd strongly recommend using only hub-centric wheels, otherwise instead of the hub bearing all the load, it's going to be on your studs/lugs.
08-16-2020, 09:07 PM | #12 |
Rep 3,002
Bore it out to 74.1mm, no it will not damage the wheels or cause an issue with the structural integrity of the wheels. Then run 74.1 metal hub-centric rings to 72.6. I've done this with wheels in the past, and it was not an issue at all.
Alternatively, you can use Plumber's tape wrap. Duct tape might be too thick depending on the brand you use. With the plumber's tape, you can create enough thickness when you mount the rim it will crush to size.
INSTAGRAM: GORDON.M3
08-21-2020, 08:02 AM | #14 |
Rep 288
I've decided I'm either going to wait for the black Apex EC-7 (9.5x19 F, 10.5x19R) or go with ESR RF1 in the same specs. Both 72.56mm center bore.
08-23-2022, 12:26 PM | #15 |
Rep 1
You might have some issues running the wheels as is. If the center bore is off by that much, it could damage the hub or be dangerous. You could try https://hubbore.com/ to see if they have any hub centric rings that would fit your wheels.
08-25-2022, 07:02 AM | #16 |
Rep 2,141
Drives: 2011 E92 M3
You can also bore the center out and have the shop press fit in new center rings.
08-25-2022, 11:52 PM | #17 | |
Rep 3,002
Adapter rings are not a problem as long as they are machined properly and tolerance is accurate.
Scharbag2626.50 |
Tags |
bore, center, hub, rings, wheel |
