      05-30-2015, 02:15 PM   #1
M3ANMACHINE
Admiral
M3ANMACHINE's Avatar
Drives: 2011 E90 M3 + 2014 F15 X5
[HELP] E90 Sedan + Recaro Sportster Floor Mounts
Issue Resolved: mounted the seat belt end directly to the floor mount/chassis bolt.
Hey guys, so I just received my Wedge Engineering floor mounts with sliders to pair with my Recaro Sportsters and I think there's a bit of an issue.
On the E90 Sedan, the end of the seatbelt attaches directly to the seat as opposed to the E92 coupe which attaches to the chassis. Therefore, an E90 sedan floor mount SHOULD have a screw hole attachment on both sides of the mount for both the seat belt receptacle on the inside, and the end of the seatbelt.
Well, my wedge engineering mounts, that I waited 2 weeks to receive, only have 1 hole on the inner side meant for the seatbelt receptacle...
So this begs the question, has anyone on the forums ever installed a set of seats in an E90 using wedge brackets?
Obviously I am dying to install my seats after waiting for so long, but I need functioning seatbelts...
I have emailed Wedge and am waiting to hear back, but I am thinking that my only options at this point are the following:
1. Send the brackets back to Wedge to have them add the second mounting point for the belt (will take at least a week I assume)
or
2. Have a custom piece made that bolts up to the floor mount that looks similar to this, but will probably need to be longer.
https://europeanautosource.com/macht...or-mounts.html" rel="" target="_blank">http://<a href="https://europeanauto...ounts.html</a>
Any help is appreciated!
Thanks
2020 FORD RAPTOR
2014 F15 X5 | M-SPORT
SOLD
2011 SG E90 M3 | 2008 AW E90 M3 | 2004 E46 M3
      05-30-2015, 05:55 PM   #2
M3ANMACHINE
Admiral
I think these might work?
https://store.vacmotorsports.com/vac...kit-p2303.aspx
2020 FORD RAPTOR
SOLD
      06-06-2015, 01:09 PM   #3
duvinclunk
duvinclunk's Avatar
Drives: 11 E90 M3 ZCP
Ever hear back from Wedge?
      06-06-2015, 05:33 PM   #4
M3ANMACHINE
Admiral
Apparently they've never made a set specifically for a sedan and were unaware of the difference in seat belt mounting.
I was able to mount the seat belt end directly to the floor mount. I will post a picture of this soon.
2020 FORD RAPTOR
SOLD
      06-06-2015, 06:01 PM   #5
s85e90
Drives: black e90
Wish I saw this sooner. I just had a hole drilled into the inside of the side mount for the seat and it was perfect.
      06-06-2015, 09:37 PM   #6
M3ANMACHINE
Admiral
Ya, that was going to be my second plan of action. Decided to mount them up first and see if I could make it work
2020 FORD RAPTOR
SOLD
      08-20-2015, 12:24 PM   #7
M3 Number 86
Drives: black m3
pics?
when you bolt into the seat, doesn't the clip have an open end resting on a metal bracket? How does it bolt in under the seat then? Does it rest against something like it does inside the side of the seat?
      08-20-2015, 03:04 PM   #8
M3ANMACHINE
Admiral
Originally Posted by M3 Number 86 View Post
pics?
I'll post up a picture shortly. Imagine the bracket being bolted directly to the floor on the rear outside corner. Simple as that.
2020 FORD RAPTOR
SOLD
      08-20-2015, 03:06 PM   #9
M3 Number 86
Drives: black m3
I did that for the Quick Fit Pros that I installed but the bracket was a complete circle (closed off) the stock ones aren't completely closed off though right?
      08-20-2015, 03:33 PM   #10
M3ANMACHINE
Admiral
I'm pretty sure they do have a fully closed hole to put the bolt thru.
2020 FORD RAPTOR
SOLD
      08-20-2015, 05:38 PM   #11
M3 Number 86
Drives: black m3
I must have mis-remembered like Roger Clemens lol. Was thinking about the hooked side that is leveraged to stay in place.
      08-20-2015, 10:25 PM   #12
M3ANMACHINE
Admiral
Ya, the closed side is bolted in, while the open side is just hanging out. Lol
2020 FORD RAPTOR
SOLD
      09-08-2015, 04:03 PM   #13
NYBulldog
Specialist
1310
Drives: Nikes
You think you could post some pics please? Not sure if its supposed to look the way it sounds? lol Thanks.
      09-12-2015, 03:08 PM   #14
M3ANMACHINE
Admiral
I'll go take a pic with my iphone. Hopefully I can get it to post.
2020 FORD RAPTOR
SOLD
      09-25-2015, 06:01 PM   #15
M3 Number 86
Drives: black m3
when's your next track day and with which group? I should just look at it in person lol.
      09-28-2015, 02:53 PM   #16
M3ANMACHINE
Admiral
Idk what happened, but the pictures didn't post and were saved in my drafts. Here they are again.
One view from the rear , and one from the front.
2020 FORD RAPTOR
SOLD
      09-29-2015, 07:36 PM   #17
NYBulldog
Specialist
1310
Drives: Nikes
That's perfect. Thank you for that!
      09-03-2019, 09:24 PM   #18
Yea Boi
Yea Boi's Avatar
Drives: Alpine white 08 M3
Have you had any problems with the seatbelt being mounted to floor?
I was also thinking about the following vac mounts, what made you not purchase them for mounting seatbelt?
My setup is different though, going with bk mounts and oem sliders, but do not know where to mount outside seatbelt mount.
