12-18-2011, 08:35 PM | #1 |
Rep 489
Clutch Delay Valve
Yes, I know a search would reveal that the E92 doesn't have one. However, it has occurred to me that MANY have written about balky shifts from 1st to 2nd (me included). Often, others suggest that maybe the clutch isn't fully engaged. Others have suggested "hesitating" between gears. Well, the clutch PEDAL is always down. However, I'm not so sure about the clutch. Anyone else know how to double clutch? EVEN double clutching I've ground 2nd gear on the 3-2 shift. Indeed, it seems like the clutch was not fully engaged when I hit 2nd.
Long and short of it, seems there could be a clutch delay valve of sorts in the car. Obviously not the same mechanism as the E46. Perhaps also not bypassable. The actuation of the pedal doesn't seem to quite match the clutch. I've read several posters have had full tranny replacements. Doesn't seem like that should be necessary. I realize this is an old topic, but I wondered if there has been any research on this that I've missed. Read all the old threads I could. Sorry, hesitating while shifting is not a solution, it is just a workaround.
E92 M3 MR on Red/Black ZCP Sound
Carbon 2007 997S - sold 2003 E46 M3 Steel Grey on Red- sold 1997 E36 M3 Arctic Silver on Black- sold |
12-19-2011, 02:33 AM | #2 |
Rep 843
Try bleeding the clutch, and try the secondary spring removal trick. Personally, I haven't yet bled the clutch, though will in a couple of weeks, but I did the spring delete and added the ebay clutch stop, and it's now much easier to consistently feel the clutch engagement point, although it's no where near perfect.
I can see how you think there's something akin to a cdv somewhere. The entire clutch engagement has a very non-linear feel to it. I don't know if it's excessive deflection in the clutch fork (i.e. a poor and weak design perhaps), or if the pressure-plate is an akward design of sorts, but something just ins't right. |
12-19-2011, 04:21 AM | #3 |
Rep 488
Drives: 2011 E90 M3 6MT
The transmission is less than ideal. There is no real solution. It is what it is.
12-19-2011, 04:57 AM | #4 |
Rep 132
Drives: M3 2012 e92 ZCP - Space Grey
12-19-2011, 07:43 AM | #5 |
ENTHUSIAST
135
Rep 2,097
Drives: 2010 Porsche Cayman
I've driven manuals for 20 years and with this manuals faults, linearity being my issue, it does seem extremely durable. IMO
"what I'm driving here...is an ending." Jeremy Clarkson
2010 Carrara White Porsche Cayman 6mt 2014 Whiteout Toyota GT-86 6mt(Sold 05/23/15) 2011 Alpine White BMW M3 6mt ZCP Coupe(forced retirement 06/06/14) 2008 Alpine White BMW 328i 6mt Coupe(retired 06/21/11) |
12-19-2011, 07:48 AM | #6 |
Rep 2,874
12-19-2011, 08:39 AM | #7 |
Rep 489
I didn't think there was a spring or there was a significant redesign, which limits the benefit on a 2011.
Hope it's durable. Otherwise, sure seems like there is some wear on the 2nd gear synchro. Agree that I'm not sure it is CDV, but something is amiss. All that have had trannies replaced are very happy. Wonder if it is just a design flaw as suggested.
12-19-2011, 09:50 AM | #8 |
Rep 521
Chances are what you are feeling is the dual mass flywheel. Do a google search on how it works, you'll see why it feels considerably different from a conventional flywheel/clutch arrangement.
12-19-2011, 08:22 PM | #9 |
Rep 132
12-19-2011, 09:21 PM | #10 | |
Rep 489
Were you suggesting a DMF would actually cause a delay in the engagement of the flywheel? I'd be very curious to know what other cars are applying a DMF.
12-20-2011, 01:49 AM | #11 |
Rep 521
the delay (likely...unless your delay is excessive) is due to the compression of one of the circumferential springs in the flywheel. if you've driven a car with a lightweight flywheel and single or multi-disc clutch capable of holding big (500 hp), you would understand why bmw went with the dmf. they had to maintain some semblance of drivability with the system, instead of a soft but barely capable clutch and light flywheel, we got a strong dual plate clutch and dual mass flywheel.
Another performance car using a dual mass flywheel, for example, is the MK4 Supra. Last edited by apecush; 12-20-2011 at 09:26 AM.. |
05-30-2013, 02:43 PM | #12 |
Rep 399
Well I'll be damned. I always thought my M3 had a CDV like my S2000, just from the way it starts off the line in 1st while loafing around daily driving. It feels like it has softer primary engagement very quickly followed a more solid secondary engagement. I was coming on here to look for CDV bypass reviews.
-David
05-30-2013, 08:35 PM | #13 |
Save the Manuals
1714
Rep 2,937
I am relieved to learn this is one mod I will not have to do when I get my car
2023 G80 6MT, CCBs
2002 330i Dinan, 5MT 2000 Z3 Conforti, 5MT |
