      12-14-2017, 04:30 AM   #1
gaz_0001
Drives: BMW M3 2012 DCT ZCP
Rear Power Sunshade - Stuck/Sticking at Top position
Hello,
I recently bought a M3 E92 2012 Model vehicle, LHD.
I pressed this rear power sunshade button on the dash. The sunshade came up.
However, now it will not go back down.
When i press the button, I hear some clicks and i can see that the two arms on the rear sunshade are attempting to contract. They move just 5 to 10mm inwards, but not enough to actually put the sunshade away.
Has anyone else had a similar issue? And can you advise me how to fix it, or how to at least put it away?
FYI - this is my first M3 and I have no experience so far with dismantling and assembling the vehicle - I am happy to have a go though.
Thanks in advance.
      12-20-2017, 04:59 PM   #2
Dubuang
Drives: M3
I have an '12 e92 m3 with the power sunshade, however I've only used it a handful of times then I tinted my car. It worked flawlessly, haven't ran into any trouble with it. It should go down relatively easy if it was working correctly.
      12-20-2017, 09:01 PM   #3
nick3753
nick3753's Avatar
1020
Drives: 2012 e92 M3 DCT ZCP
2017 Audi S6  [0.00]
1997 BMW 328i Touring  [0.00]
2012 BMW M3  [0.00]
I had mine replaced under warranty for the same issue. I've used it a dozen or so times since (maybe 2 years) and it broke again. Just leave it down (it looks ugly anyway) and get tint.
Edit: to put down you will need someone to push the button while you give a nudge to the side bars. Just push them towards the center of the car and it will come down.
      12-20-2017, 09:23 PM   #4
Atomicteal_M3
Atomicteal_M3's Avatar
Drives: E90 M3 AW
2007 335i  [9.00]
Same issue with mine. From what I've heard and extensive research, the motor is going out. You will need to replace it with this part. https://www.ecstuning.com/b-genuine-...k/51469149848/ Not worth replacing to me but if it's in your budget, feel free!
      12-21-2017, 01:44 PM   #5
JDM_CL9
JDM_CL9's Avatar
Drives: ///M3
2009 BMW E93 M3  [0.00]
In case you don't have someone to help... I just sit in the back seat; hit the button; then quickly push the arms inward. You may need to be a bit of a Ninja to get it to work though...
2009 BMW E93 6MT///M3 - SG/FR
2011 BMW E90 DCT///M3 - JB/FR (Sold)
      12-21-2017, 01:50 PM   #6
nycplumber
Drives: slow
What all the other replies said are spot on. You could also get something to 'poke' the button while you're applying pressure on the vertical arms.
      02-02-2018, 04:30 PM   #7
330ciprem
330ciprem's Avatar
229
Drives: 12 E92 M3, 06 E46 330ci, 6spds
Facing the SAME issue. Got the M3 1 week back.
It was going up and down properly before but today when it came up it's not going down.
I have a feeling the 11 F is the issue. The temps were fine till yesterday and the shade was working fine as well. Gonna leave her in the garage for a couple of hours and hope for the best.
Just a feeling.
      02-02-2018, 04:31 PM   #8
TomHudson
Drives: 2011 E90 M3
Put a bit of penetrating oil on the hinges.
