  TireRack
      09-17-2013, 08:28 PM   #1
hurtwj
TRUE WARRANT OFFICER 3 /BLACKHAWK DRIVER
hurtwj's Avatar
Drives: BMW M3 E90 SG
Rear camber maxed out
I have lowered my suspension on H&R sport spring which gave me a 1.5 drop in the rear. I have been told that my camber in the rear is maxed out and cannot be adjust anymore. Is there any thing that I can do ? Is there any type of aftermarket camber plates for the rear? If so who makes it?
08 E90 M3 Sparkling graphite
BC FORGED RACING WHEELS 19X8.5, 19X11 21&22LBS ,Blacked out side markers, CARBON FIBER EMBLEMS, H&R sport springs, HARDWIRED V1
      09-17-2013, 08:36 PM   #2
Malek@MRF
Malek@MRF's Avatar
Drives: E92 M3, 991 P-Car
Send a message via AIM to Malek@MRF
At 1.5" of lowering, there should be no way the rear camber adjuster is maxed out. Either they have the wrong alignment specification data for your M3 or they don't know what they are doing. The M3 lower rear control arms have plenty of camber adjustment. The car also has plenty of room for toe adjustment as well.
      09-18-2013, 04:30 AM   #3
Dartanium
Drives: 09 E90 M3
my question is the same, several shops have metioned that roughly -1.0 to -1.1 is the maxiumum at rear even at OEM height? Is there certain technical hill one must master before achiving anything more than -1.5? I am not sure what is this particlar techincial diffculty
      09-18-2013, 06:24 AM   #4
arter
collecting toys
arter's Avatar
31
Drives: M3 MCB
It is quite easy to get -2.0 on the rear stock height.
There is an elliptical washer on the rear arm that is adjusted. Stick your head under your car and see how much it is turned. Mine is only turned about 2/3's of the way to get -2.
2011 e92 M3 Monte Carlo Blue ESS 535 - gone but not forgotten
2015 cayman GTS - new toy
2006 SLK 55 AMG sold
      09-21-2013, 12:19 AM   #5
hurtwj
hurtwj's Avatar
I will check and see what else can be done
      09-21-2013, 12:20 AM   #6
hurtwj
hurtwj's Avatar
If it is maxed out what else can be done?
      09-21-2013, 12:30 AM   #7
1MOREMOD
2018 track days - 0 ridge 1:52:24 pacific 1:33:30
1MOREMOD's Avatar
Drives: Race car->
if it is maxed out and you are lowered by 1.5 inches you have -3 or more in the rear and that is too much.
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs|
      09-21-2013, 12:58 AM   #8
hurtwj
hurtwj's Avatar
Thanks.
Search this Thread:
Advanced Search
