      10-26-2014, 12:20 PM   #1
jagman
jagman's Avatar
Drives: 2008 Alpine White E92 M3
Persistent Power Steering Leak After Flush
My brother-in-law is almost done doing a major service on my E92 M3 but we are having problems with the power steering fluid leaking after reassembly. We got the correct crush washers from the dealer and after tightening the banjo bolt as much as he can it still leaks. We have taken it apart and reassembled it with the original ones which helped and this was the best but it still has a slow leak and a leak is a leak. Any suggestions on what to do? It is very frustrating
2008 AW E92 M3: Stage II and DCT tune by BPM Sport, convenience coding + coding for mDrive w/Euro MDM (no iDrive) & alarm retrofit by BPM Sport, Fox Red interior, ESS midpipe, Corsa slip on exhaust, carbon fiber M Performance spoiler, black grills, black OEM M3 ZCP 19" wheels, 15/12mm spacers and AW painted reflectors
      10-26-2014, 02:05 PM   #2
tinman831
Drives: M3
What is leaking? The lines leading to the rack or the lines leading to the reservoir? I believe there's a specific torque for those. If you tighten too much you could crack the line.
      10-26-2014, 03:05 PM   #3
jagman
jagman's Avatar
Ohh. It is leaking at the crush washers.
      10-26-2014, 06:35 PM   #4
tinman831
Drives: M3
It's 30ft lbs for the e46. Did you make sure to use two washers for each bolt? Also check the lines to make sure the old washers aren't stuck on them or the rack.
      10-26-2014, 07:20 PM   #5
jagman
jagman's Avatar
Yes. We used two new washers and the old ones were off. We put back the old ones and it leaked less but it still dripped. We compared the new and the old and the sizing seems identical. It's really weird.
      10-26-2014, 07:24 PM   #6
jagman
jagman's Avatar
I'm pretty sure just one connection is leaking and it has two washers. I texted my brother in law to confirm. I'll get back when I know more.
      10-26-2014, 08:40 PM   #7
jagman
jagman's Avatar
Yes. I confirmed two washers per bolt. He thinks it's the lower connection that is leaking.
