BPM
      02-18-2009, 12:53 AM   #1
JamesClay
JamesClay's Avatar
144
Drives: BMW 3
1996 320iT  [0.00]
2003 M3  [0.00]
2006 325i  [0.00]
2008 M3  [0.00]
Performance Friction dropped a skid at our place today...
The good stuff is finally here! I dropped off my car for measurement last summer for a few weeks and after the madness of Daytona is over, we finally get what we have been waiting for! This is the 4-wheel kit, Z31 monobloc calipers (CNC machined from a solid forging, not a casting - only one in the industry), 372mm front/371mm rear (hmmm....). Our requirement wasn't that they fit under 18" wheels, but I am thinking they will - more to come on test fiemtents. For now, the stars of the show:
Z31 Caliper - 5 pounds of forged aluminum goodness, but the velvet bag alone is worth the ticket price! Almost.
The powdercoating hides the cool machined (again, not cast...) features, but necessary to pass a true OEM-spec salt-spray test.
A look through the bridge. Note the piston caps that reduce heat transfer and insulate from noise - versus the normal direct piston/pad contact of other calipers.
A car's worth of pads - 16 of 'em. Each caliper uses 4 pads for more bite and torque. Does it work? Several race sanctioning bodies specifically limit the number of pads per caliper because of them, so results say yes...
Note the FEA-designed moulded chamfer on the pad edge, specifically designed for noise and performance, not cut into the pad after pressing with a saw. Also, on these pads the design is assymetrical, meaning pads are directional and again, the result shows that the extra bit of engineering is worth it.
Rotors - Direct Drive V2 - debuted in Cup last year, we got them on the World Challenge cars middle of 2008 season. The design saves 0.5 pounds per corner over the V1 PFC bobbin mount. Oh - and these are both cast AND machined in the USA, not in Asia.
Note the machined surfaces all around the rotor. Machining rotor faces are standard, and some machine the OD. Also machined for trueness and thermal balance is the ID of the friction surface, as well as both the ID and OD of the vein surface...
And the 372/371 rotor size - specific for creating the balance needed since you can't just swap around piston sizes with the ABS system used in the car and get the balance you want. Would certainly have been easier to make both the same size, but as frustrating as it is at times for us, PFC has razor-sharp vision of what they want and they don't compromise in the least for ease of implementation - part of my 6 month wait for kit design.
Will test on track in a week and a half. If we get REALLY motivated, we may try to do a back to back test, but I am not sure I have the help that weekend to have an accurate test.
      02-18-2009, 01:16 AM   #2
JamesClay
JamesClay's Avatar
144
Drives: BMW 3
1996 320iT  [0.00]
2003 M3  [0.00]
2006 325i  [0.00]
2008 M3  [0.00]
One more for the night... Here is that caliper in race trim, without the powdercoating - machining is much more evident and technically cool I think, but I have had brakes get hit with even limited winter driving and be a mess.
      02-18-2009, 02:19 AM   #3
CraZee M3
Drives: 09 E90 M3 DCT
wow very nice... performance friction makes some quality brakes!
nice to see them making stuff for the bimmers now.
      02-18-2009, 03:05 AM   #4
M3WC
Drives: BMW
James good luck this season in Speed Touring Car.
      02-18-2009, 08:23 AM   #5
Radiation Joe
Veni Vidi Vici
Radiation Joe's Avatar
Drives: '11 JB/BBe-6sp-e90
2011 e90 M3-Sold  [8.50]
2003 RS6 - Sold  [0.00]
2009 e90 M3 - Gone  [0.00]
2003 M3 SOLD  [0.00]
old 2002  [10.00]
Weight savings over stock?
      02-18-2009, 08:53 AM   #6
SlammedR8
SlammedR8's Avatar
Drives: 2019 X5 40i/2020 R8 V10 Spyder
How muchhh?
Current:
2019 BMW X5 40i - Carbon Black/Tartufo Individual Leather
2020 Range Rover HSE - Black/Black
2020 Audi R8 V10 Performance Spyder 6MT - Ascari Blue/Black
      02-18-2009, 09:24 AM   #7
Radiation Joe
Veni Vidi Vici
2003 M3 SOLD  [0.00]
old 2002  [10.00]
Really? You can't go to the Bimmerworld website and look this up yourself?????
Originally Posted by slammedm3 View Post
How muchhh?
      02-18-2009, 09:36 AM   #8
consolidated
consolidated's Avatar
205
Drives: F80 M3
$8K is a choker but very nice kit, wish they weren't painted but completely understand why they are.
      02-18-2009, 09:42 AM   #9
JamesClay
JamesClay's Avatar
144
Drives: BMW 3
1996 320iT  [0.00]
2003 M3  [0.00]
2006 325i  [0.00]
2008 M3  [0.00]
Will get some good measurements when installing, probably next week. I expect it to be pretty decent with that goofy "simulated caliper" bracket the car uses.
      02-18-2009, 09:43 AM   #10
lucid
lucid's Avatar
Drives: E30 M3; Expedition
This source claims the stock calipers are 7.4 lbs, so that is significantly lighter.
http://bmwfans.info/original/E92/Cou...4/ill-34_1618/
I would assume the rotors weight close to stock to maintain thermal mass. It sounds like you are saying the hats save 0.5 lb, but the pads seem larger, so maybe the total weight savings is around 2-3lbs per corner?
Thanks for sharing info on this setup.
      02-18-2009, 09:47 AM   #11
Omar@ActiveAutowerke
Looking good James!
Your will need those for those amazing power upgrades
      02-18-2009, 10:15 AM   #12
JamesClay
JamesClay's Avatar
144
Drives: BMW 3
1996 320iT  [0.00]
2003 M3  [0.00]
2006 325i  [0.00]
2008 M3  [0.00]
Probably more significant than that - that is a great way to cheat the numbers though - the stock caliper bracket is huge, cast steel, and I am betting pretty heavy.
Rotor weight - also probably a bit less than stock. The 0.5# I referenced was weight savings between these rotors and a PFC Version 1 - both typically a bit lighter than stock.
Will have the real numbers shortly.
Originally Posted by Active Autowerke View Post
Looking good James!
LOL - the exhaust note draws huge attention at the track - more so than the "exotics"...
      02-18-2009, 10:26 AM   #13
Cool, good to hear. Send us some more info on these brakes when you get a chance...
      02-18-2009, 11:08 AM   #14
JC919
Drives: CSL
Nice, I've been waiting for these.
      02-18-2009, 12:04 PM   #15
Radiation Joe
Veni Vidi Vici
2003 M3 SOLD  [0.00]
old 2002  [10.00]
Stock caliper and bracket are 11.4 lbs, from the same source. Significant decrease in weight.
Available in black or only red?
      02-18-2009, 12:23 PM   #16
JamesClay
JamesClay's Avatar
144
Drives: BMW 3
1996 320iT  [0.00]
2003 M3  [0.00]
2006 325i  [0.00]
2008 M3  [0.00]
We order PFC in black only - I can custom order other colors if a customer is willing to wait. So the red here...I am guessing that that is what the owner wanted me to have so that is what I got...
      02-18-2009, 12:47 PM   #17
mtechnik3
mtechnik3's Avatar
Drives: 2020 M2C
Those look great James! Can't wait to check out your M3 at Road. Atlanta with the Moton installed!
2020 /// M2 Competition
Past: 2016 435i ZHP Edition | 2013 335i | 2011 135i | 2008 328i | 2006 325i
      02-18-2009, 01:24 PM   #18
lucid
lucid's Avatar
I am confused about this one. How do these PC calipers bolt onto suspension? Does the 5lb figure include brackets?
      02-18-2009, 01:30 PM   #19
08M3
MY 4TH M
08M3's Avatar
10
Drives: 08M3 AW
you guy's have any pictures of the car yet?
      02-18-2009, 01:32 PM   #20
JamesClay
JamesClay's Avatar
144
Drives: BMW 3
1996 320iT  [0.00]
2003 M3  [0.00]
2006 325i  [0.00]
2008 M3  [0.00]
Small aluminum brackets from BBKs are almost an order of magnitude lighter than the stock E92 M3 piece.
For a short-term answer, what is the total weight of all stock parts? Caliper, bracket, pads, rotors - or let me know what is excluded from the published weight. I will weigh a pile of parts on my end.
Car loaded in trailer to get clearbra and a bumper touchup - looks like I will be tracking it more than originally planned...
      02-18-2009, 01:36 PM   #21
lucid
lucid's Avatar
Member Badfish weighed the OEM setup. Front calipers+brackets+pads+line weigh ~14.5 lbs, rears weigh ~11 lbs. Details on that here:
http://www.m3post.com/forums/showthread.php?t=170932
Other weight savings items here:
http://www.m3post.com/forums/showthr...ngs+benchmarks
      02-18-2009, 02:41 PM   #22
JamesClay
JamesClay's Avatar
144
Drives: BMW 3
1996 320iT  [0.00]
2003 M3  [0.00]
2006 325i  [0.00]
2008 M3  [0.00]
Hmm - enough variation in the two sets of measurements that I will probably do two complete piles of parts, on the same set of scales...
