05-21-2022, 12:09 PM | #1 |
Rep 270
Exhaust too quiet now
Alright so I recently switched to a Corsa catback with the Evolve x-pipe with HFC's. Sound is much more refined and controlled and has no rasp which I wanted. Problem is now it is too quiet. My previous issue with my valved system was not that it was too loud but rather way too raspy. Now there is zero drone or rasp but it much too quiet for my tastes.
So now the question begs what can I do to make my system louder without introducing rasp? I want to keep the Corsa as I like the exotic note it has. That being said, do I need to switch back to a catless x-pipe or delete resonators? The corsa has mini resonators built in and a Helmholtz chamber so it is quite good at reducing noise. I think in order for me to get the volume I want I would need to delete the resonators but keep the cats to keep things still refined. If I delete cats and resonators I think it would be too much. Thoughts? |
05-21-2022, 04:25 PM | #2 |
Rep 1,230
I can't help but I am 1-2 steps behind you. Currently have an armytrix exhaust paired with a quad resonated bimmerworld x pipe and its LOUD in open. I am thinking of switching to corsa but wondered if I should add a HFC. Do you have any videos of your current set up?
05-21-2022, 07:24 PM | #3 | |
Rep 270
I think adding a HFC might help a bit with the sound but it is not going to make a significant change. I know there are folks on this forum who have made double digit exhaust changes and can weigh in. |
05-21-2022, 08:00 PM | #4 |
Rep 1,230
I love that in quiet mode it has zero drone but I dont love that when it's open you can hear it from many blocks away. I worry that adding just a corsa will make it drone on the highway and maybe I should start with HFC and go from there. As far as sound level a resonator will do nothing for volume but getting rid of a cat certainly will make it louder
05-22-2022, 09:09 AM | #5 |
Rep 444
I went through a similar experience recently. Installed a BW resonated x-pipe with Corsa exhaust, which is known to have a slight rasp in the lower RPMs due to the forward placement crossover and Magnaflow resonators. Decided to add HFCs to reduce fumes and immediately noticed a reduction in volume that I didn't like.
Went back to BW resonated x-pipe without HFCs and volume wise it's perfect. To combat the rasp, solution seems to be to replace the factory installed Magnaflow resonators with quality resonators such as Vibrant. In your case, I believe you need to go to a catless, quad resonated setup achieve the increased volume you're looking for with little to no rasp. |
nycplumber686.00 SnohoRaptor534.50 |
05-22-2022, 11:36 AM | #7 | |
Rep 754
So stock xpipe, tp's out to a Corsa was so damn good. I sold my old E90 M with that setup, and with my new e92 I put an RKP, with that same corsa and it doesn't sound nearly as good as just gool ol Test pipes out to the corsa rear. I will be heading to ACM soon to remove the RKP and put test pipes back in. |
drwankel1049.00 |
05-22-2022, 11:39 AM | #8 |
Rep 270
After some thought I do not want to go back to being catless. I prefer my car to not smell like a go kart especially when I am driving to important meetings. Thus my only other option of getting some more noise out of the car is removing the resonators on the evolve pipe.
Before I decide to hack up or sell this x pipe I wanted to do a little research. After some digging it looks like the Evolve pipe is actually made by Supersprint and just rebranded. I did some research and Supersprint sells their x-pipe in sections. I was able to find this piece here. Does anyone think I could simply remove the portion with the resonators and replace it with this piece which bolts up to the cats? I would have to have a shop cut down to length the connecting pipes as Supersprint unfortunately designs this only to work with their exhaust systems. I'd rather try this first then hack up the evolve pipe as it will be difficult to sell if I go that route. The only other option I can think off is just have a shop fabricate a section to connect from the cats to the corsa and I am not sure if this would be cheaper to do. No one else sells an x pipe with HFC without resonators. AFE is the only one I can think off and they put the cats in the primary section which I do not want. |
05-22-2022, 11:43 AM | #9 | |
Rep 270
buzzybee43.50 |
05-22-2022, 12:53 PM | #10 | |
Rep 754
My buddy who has an e9x swears my cars are always quiet and I am like, what? It's loud as hell lol. |
05-23-2022, 09:19 AM | #11 |
Rep 550
I am adding HFCs to the secondary position on a BW resonated x pipe.
I want the Corsa exhaust and am hoping to get close, with even less rasp perhaps, as the ess x pipe and corsa combo. With 2 200 cell cats in secondary, resonators - will upgrade if needed and then the Corsa, I am hoping for 0 drone, 0 rasp, only light smell of fuel. |
05-23-2022, 09:43 AM | #12 | |
Rep 270
05-31-2022, 02:49 PM | #13 |
Rep 270
Bumping this thread with my previous response before:
After some thought I do not want to go back to being catless. I prefer my car to not smell like a go kart especially when I am driving to important meetings. Thus my only other option of getting some more noise out of the car is removing the resonators on the evolve pipe. Before I decide to hack up or sell this x pipe I wanted to do a little research. After some digging it looks like the Evolve pipe is actually made by Supersprint and just rebranded. I did some research and Supersprint sells their x-pipe in sections. I was able to find this piece here. Does anyone think I could simply remove the portion with the resonators and replace it with this piece which bolts up to the cats? I would have to have a shop cut down to length the connecting pipes as Supersprint unfortunately designs this only to work with their exhaust systems. I'd rather try this first then hack up the evolve pipe as it will be difficult to sell if I go that route. The only other option I can think off is just have a shop fabricate a section to connect from the cats to the corsa and I am not sure if this would be cheaper to do. No one else sells an x pipe with HFC without resonators. AFE is the only one I can think off and they put the cats in the primary section which I do not want. |
06-01-2022, 09:49 AM | #15 | |
Rep 270
https://www.youtube.com/watch?v=XBb4t8Z1sCM |
06-01-2022, 10:42 AM | #16 |
Rep 1,230
It could be louder for sure but when I went from gutted stock x pipe to bimmerworld it was significantly quieter. The stock x pipe and bimmerworld are both similar to the designs youre looking at and I achieved the opposite of what you're looking for fwiw.
06-01-2022, 03:25 PM | #17 | |
Rep 550
If you want it louder, take out the cats on your xpipe, but add resonators for a refined sound. I really think this car needs either : No main cats - 4 resonators different sizes before and after x merge - loud but refined - Dinan style or no main cats - 2 HFC in secondary position (200 cell) and 2 resonators towards the rear. This will reduce drone and rasp but elevate volume over stock. - almost everything else. People sort of functionally do the above when they do test pipes. I am not a high enough roller to get the best cats for primary position that also provide performance similar to catless set ups. There is more to it but that is all I can contribute right now. |
06-02-2022, 07:59 AM | #18 | |
Rep 270
06-02-2022, 01:37 PM | #19 | |
Rep 550
Have you considered the 4 pipe mod? the 2 pipe ACM method, is not for me but also even louder. the ACM method makes it almost straight piped but with a resonance chamber. Maybe that could be an option? and cheap too. Bottom line - before you ruin your Corsa exhaust, sell it to me. hah |
06-02-2022, 05:35 PM | #20 |
Rep 225
Not my video, but I have this same setup:
Corsa rear section with catted ESS x-pipe. It’s pretty quiet in the cabin when cruising (no drone), but you can hear it when you romp on the throttle. It’s also a lot louder out back or when you crack the window. Sounds great imo. |
06-03-2022, 09:46 AM | #21 | |
Rep 270
So I would not be altering the Corsa at all, I am considering removing the bolted on portion of the Evolve pipe where the resonators are with a non-resonated connecting pipe. I would have to have an exhaust shop cut the pipes as this particular one is designed for supersprint systems only. The reason I am doing it this way is to not hack up the Evolve pipe should I decide to sell it. Worse case it is no louder and best case it is. Like I said I love the Corsa sound I just want it louder and I am ok with a bit more rasp if that means more volume. |
06-03-2022, 01:18 PM | #22 | |
Rep 4,147
Mods: Yes.
jp1984506.00 |
