04-19-2022, 09:32 AM | #1 |
Rep 270
Active Autowerke or Evolve Catted X Pipe
Narrowed my selection down to these two options as it seems these are the only two readily available with HFC's and resonators (unless someone else knows of any others). Active has the HFC's in the primary while Evolve is in the secondary. I do want to do a Stage II tune at some point so consider that as well.
As far as smell, sound, etc can anyone comment here? Plan on pairing with a Corsa axelback. Also it seems Active is selling their new pipe with GESI 400 cell cats? This might be a problem if you want to do a Stage II. I have seem older versions that were 100 or 200 cell. Thoughts? https://store.activeautowerke.com/pr...high-flow-cats https://www.evolvetuning.us/brands/e...92-e93-m3.html |
04-19-2022, 11:41 AM | #2 |
Rep 550
I have literally been thinking this through and came up with maybe a superior option.
Macht Snell X pipe ~ $1,000 HFCs welded in where the pipes connect ~ $400 with parts and labor wouldn't that bring you shocking close to the evolve piece at a fraction of the cost? I just can not help but think that a quality x pipe brought to an exhaust shop with HFCs can not basically recreate the Evolve one, am I crazy? Because I am thinking this is what I might do and give up on the forward x position pipe. https://www.vividracing.com/-p-153119235.html https://www.amazon.com/dp/B000VX96IS?tag=wvdot-20 |
04-19-2022, 02:33 PM | #3 | |
Rep 270
04-19-2022, 06:21 PM | #4 |
Rep 259
https://www.topgear.co.uk/bmw-m3-v8-..._type=exhausts Website says they have 9 in production. And this one. Its not in US dollars BTW. https://m3world.com.au/shop/exhaust-...catsresonator/ Last edited by bravehart38; 04-19-2022 at 06:27 PM.. |
04-19-2022, 07:42 PM | #5 | |
Rep 550
I can not speak directly either way but I had that in my sights for a little bit. Its too bad these are such a pain to return. and uninstall. |
04-20-2022, 09:33 AM | #6 | |
Rep 1,027
Steve::::2012 AW E92::::IG - @sjs0433
jp1984506.00 |
04-20-2022, 11:50 PM | #8 |
Rep 259
RKP is discontinued until further notice.
04-20-2022, 11:54 PM | #9 |
Rep 259
Different companies. Top Speed is in my backyard here in Texas. Top Gear is actually based out of the UK but they have distro here in the US
04-21-2022, 08:49 AM | #10 |
Rep 270
Pulled the trigger on the evolve pipe. Was able to get it at a discount going through these forms as the price went up right before. Shoutout to Imran@Evolve for the hookup.
To comment on the other options, RKP is gone and I cannot speak to the quality of Topspeed or Topgear. The issue with these cheaper x pipes with HFC's is that the quality of the cats is garbage usually. EDIT* Also topspeed and AFE has the HFC's in the primary position which I did not want |
Imran@Evolve5371.00 |
06-06-2022, 10:07 AM | #11 | |
Rep 20
06-06-2022, 10:58 AM | #12 | |
Rep 270
Secondly, almost all manufacturer's who put HFC's in the primary spot have clearance issues. It is very common for people to scrape the cats going over bumps especially if you are lowered. With all that in mind, Evolve/ M3World and TopGear are the only manufacturers I know that still makes an x-pipe for this platform that puts the cats in the secondary position. I went with the Evolve pipe because of the dyno numbers to back it up and was able to get it on sale. https://www.topgear.co.uk/bmw-m3-v8-..._type=exhausts https://m3world.com.au/shop/exhaust-...catsresonator/ https://www.evolvetuning.us/brands/e...92-e93-m3.html Last edited by rjsiciliano; 06-06-2022 at 11:03 AM.. |
06-06-2022, 01:06 PM | #13 | |
Rep 550
FWIW, unless someone really wants to pay the premium for an xpipe with preinstalled cats. You can still definitely take a cheaper x pipe ($1200) buy some 200 cell cats 2.5 inch in and out ($200) and bring it to an Indy or Exhaust shop and they will install it and weld it for like $300 total. $1,700 instead of a bit more expensive one pre installed but, I understand some people don't like the extra hassle. And yes, a member has noted that primary cats on a tuned and tracked car could cause trouble, I believe him. Much better to put some in the secondary position and not worry about it. |
06-08-2022, 12:18 PM | #14 | |
Rep 1,047
06-08-2022, 06:01 PM | #15 |
Rep 580
In addition to this, cats in this position CAN result in additional pedal vibration (but not always). I had an AA X-pipe and got rid of it for an Akra Eve and pedal vibration went away. Search the forums, this seems to be more common for AA x-pipes.
2013 E92 M3 Mineral White Fox Red / Black
rjsiciliano158.50 |
06-09-2022, 08:20 AM | #16 |
Rep 270
No rasp, no drone, sounds great and exotic. Only thing I wish it was just a little louder. When I first had it installed the shop commented on how quiet it was just driving off. It is growing on me a bit but I may sell down the line not sure yet. The evolve pipe is one of the more quieter x-pipe setups I think. The resonators are quite large and the cats appear to be very substantial 200 cells. I am looking at the Borla Atak as my next choice. Sounds like just enough volume increase while still remaining relatively drone free. This is not my daily driver so when I do drive it I want it to be heard haha.
06-09-2022, 10:01 AM | #17 | |
Rep 1,047
06-09-2022, 10:15 AM | #18 |
Rep 270
I have only ran the Corsa with evolve pipe. My guess is with stock x pipe it would be considerably quieter. To the point where you would not even know you had an aftermarket exhaust on. If you are going to get the Corsa at the minimum get test pipes to delete primary cats.
06-09-2022, 12:33 PM | #19 | |
Rep 1,047
I tried another x pipe in the past and it was WAY too loud vs test pipes, and went back to test pipes. Just considering options if I need to do something like an x pipe swap for emissions inspection if I ever need to worry about that in the future. Putting my stock x pipe back together, and then having another one I can easily change out would be a workable solution. |
06-12-2022, 02:16 AM | #20 | |
Rep 4,147
Be weary of people who say this and have nothing to substantiate it with. I think evolve stuff is typically overpriced, and never has the performance to back up the bling. A good X PIPE should have the HFC AFTER the merger, because the merger is where the power is actually made (scavenging) |
06-12-2022, 04:32 AM | #21 |
Rep 3,789
The Evolve X Pipe has been dyno tested independently many times since its inception in 2013. Its a known quantity. Not sure how you are trying to shade on a product that has been in the market for so long. If it didn't do what is advertised it would be common knowledge.
https://www.m3post.com/forums/showthread.php?t=891096 We are going through the whole tuning process on this platform again so we can document it with Dragy acceleration times so we will be able to back this up with performance data too. |
06-12-2022, 01:57 PM | #22 | |
Rep 270
Do you have an example of another x pipe that has quality HFC's with dyno testing to back it up that you can still buy right now? Maybe in the past there were cheaper options but not anymore. No one makes mid sections for this platform (With HFC's) except for a select few Evolve being one. |
