03-07-2014, 04:48 PM | #1 |
Rep 58
Drives: BMW M3
pulleys
okay so im looking into pulleys for my 2013 e92 m3, but i been seeing all these negative posts about how they got problems making weird noise and how dinan says dont bother with these upgrade and so on. does anyone have pulleys that have no problems what so ever with this upgrade?
03-07-2014, 05:21 PM | #2 |
Rep 2,400
Have the Dinan pulley and it does make a light squealing noise once in a while when cold at full steering lock (something you're not supposed to do anyway) but Dinan assured me that it's normal. However, there are no other problems with it, and temperatures (both oil and water/coolant) are just a few degrees (maybe 3) higher than stock when on the track. Hard to feel a power difference as it is mostly at high rpms, but dynos definitely show proven gains of 10-11 hp if you're into the "every hp counts" type of view.
03-07-2014, 05:24 PM | #3 |
Rep 1,128
Drives: 2013 E92 M3, 2016 X5 50i
Got AA and never had any noises or problems with it! Which is coming off soon as I bought an ESS SC!!!
I Am The Strength Behind The Fight!
03-07-2014, 06:43 PM | #4 | |
Rep 18,823
Drives: BMW
Bang for the Buck Mods: Macht Schnell UDPs & Dyno Findings http://www.m3post.com/forums/showthread.php?t=649151 Let me know if you have any questions.
03-07-2014, 08:55 PM | #5 |
Rep 1,130
Does anyone know if there is a brand of pulley that doesn't underdrive the power steering? I ended up taking my pulleys off because I did not like dealing with the power steering lag and stiff steering at low speeds.
03-07-2014, 09:11 PM | #6 |
Perception is King
131
Rep 1,703
I have a Dinan, never once ever has made a noise and there the only company that doesnt effect warranty and the BMW dealer uses there stuff. Best pulley hands down IMO.
Perception and Reality are Two totally different Things.
03-07-2014, 09:31 PM | #7 | ||
Rep 3,742
That said, my biggest gripe with the Dinan pulley is that the power-steering belt is crazy, insanely, unbelievably hard to install. I literally could not get it on with help from another member here. It also stumped several mechanics at BMW dealerships, including one who installs a lot of Dinan stuff. Thus, I am a bit worried about what might happen if the belt breaks and I need to replace it. If I had to do it again, I'd probably have gone with a Turner pulley. Aside from being a big fan of Turner stuff in general, my understanding is that the belts for their pulley is not as much of a gigantic PITA as the Dinan ones. |
03-07-2014, 09:43 PM | #8 |
Rep 18,823
Drives: BMW
Not true. Dinan will provide their own warranty for the remaining term of your BMW warranty period.
03-08-2014, 03:39 AM | #9 |
Rep 4,381
Really?...its what, a 20% underdrive pulley? and that gives 10hp. So if you ran no belts at all you would gain ~50hp. A water pump and a PS pump (plus a freewheeling alternator and AC pump at WOT) consuming the same amount of power as a small car! That doesn't sound very likely.
03-08-2014, 08:49 AM | #10 | ||
Rep 453
03-08-2014, 08:59 AM | #11 | |
Rep 4,381
03-08-2014, 09:25 AM | #12 | |
Perception is King
131
Rep 1,703
I live in Michigan and its COLD, drove it yesterday it was 40 degrees and wet from melting snow and even at full lock no noise at all.
03-08-2014, 01:53 PM | #13 | |
Rep 2,400
Yes, really.
03-08-2014, 04:48 PM | #14 | |
Rep 3,742
03-08-2014, 07:43 PM | #15 |
Rep 2,400
Would like to know the trick as well... Dinan service center put on my pulley so don't know what they did. I remember someone saying a while back that they heated the belt to get it around the tensioners, but always wondered if this was true.
When I brought in my car for the installation of the strut braces, I mentioned the squealing noise at full lock and they said that was completely normal (even checked the bolts on the pulleys). The mechanic assured me that the belt "is never coming off" due to the deliberate undersizing of it. |
03-08-2014, 07:55 PM | #16 |
Grown Azz Man
429
Rep 3,021
Another bump for the Dinan pulley. I've been running it for about 37k miles and the gains are noticeable above 3500 rpm. Also, the magic squeal at full lock is normal. Operating temps and steering feel are great.......even while on track in the Houston heat .........Phil
2016 GT4.....Sapphire Blue Metallic, Platinum stitch Leather/Alcantara interior, Carbon Fiber Trim, PCM w/Nav, Guards Red Belts, 2 Zone Climate, Sport Chrono, LWB, Smokers Pack, Big Gas Tank, Light Design Pack, Bi-Xenon w/PDL, Auto Dim Mirror, Clear Side Markers, GTS Clear Taillights
03-09-2014, 08:58 AM | #17 |
Rainbow Racer
1008
Rep 2,539
I like my pullies, but the p.s. pulley doesnt grab the belt very well and I can twist the pulley with my hands despite the belt on there as tight as it can be.
its not worrisome, but it does make an awful noise after you wash the engine bay.... |
03-09-2014, 11:12 AM | #18 | ||
Perception is King
131
Rep 1,703
EDIT: I should add if you can have a second person simply push down on the ratchet it makes it even easier, use a long ratchet if you can also.
03-12-2014, 02:08 PM | #19 |
Rep 58
Drives: BMW M3
awesome input guys! keep you all posted after my tune and pulley install!
03-20-2014, 08:03 PM | #20 |
Rep 4,001
Grigio Telesto M4, 6MT. Coyote 5.0 F-150 991 GT3 |
