12-12-2017, 09:19 AM | #1 |
Rep 144
hey, I had a cyl 1 misfire in my e90 m3 the other day. ordered new plugs and coils. swapped them out today and reset diagnostics. still getting cyl 1 malfunction. ran my auto enginuity diagnostics and it looks like im not getting any fuel to the injector. is my injector bad or am I having another issue? thanks in advance. [IMG]undefined[/IMG]
12-12-2017, 10:49 AM | #2 |
Rep 1,148
Drives: 2008 BMW M3 Coupe
Garage List 2015 Jaguar XJ [0.00]
2015 Jaguar XF [0.00] 2014 VW GTI [0.00] 2008 BMW M3 Coupe [0.00] 2007 VW Passat 2.0T [0.00] |
It's hard to say. You can try swapping out injectors between cylinders to see if the misfire tracks the injector or remains with cylinder 1.
Nickdm316.50 |
12-12-2017, 12:23 PM | #5 |
Rep 1,256
I'd still go and check physically at the connector.
12-13-2017, 06:32 PM | #6 |
Rep 465
12-13-2017, 06:36 PM | #7 | |
Rep 144
Ill find out this weekend when I have time. |
12-17-2017, 04:21 PM | #8 |
Rep 144
ok, so after checking the injector on cyl 1, I found that it was good. I compared it to the other resistance readings on the other cylinders . all the same. went back to the coil and starting comparing resistance on the other coils. the new coil I put on cyl 1 was bad too. sent it back and ran over to the dealer. bought a new coil and all good. all back to normal. reset codes and driving again. thanks for all the help guys
