06-16-2011, 10:44 AM | #1 |
Rep 3,293
Calgary - Need help installing..
Side gills
I've looked at all the DIY guides possible on this forum and I still have NO idea how to get this done, I got the front grilles on and reflectors with-in about 30 minutes but these side gills are impossible.. I'll include pictures to show my problems, if there is anyone in the Calgary area that could help me with the installation it would be GREATLY appreciated.. This is what I got from the vendor (Won't mention names in case they forgot to send something) Next.. I cannot get the metal clips out Last.. I have NO access to this screw, it is impossible because of the black plastic running across the top of it Somebody please HELP me Also it's for a 2011 E92, I know this makes a difference because I do NOT have the honeycomb on the sides like previous model years.. Thanks guys Last edited by BMW Fanatic; 06-16-2011 at 11:03 AM.. |
06-16-2011, 08:43 PM | #3 |
Rep 1
I have installed them on my 2011. They are a pain to remove but not impossible. I live in the NW part of Calgary and would be more than happy to help/show you how to do it if you would like.
06-16-2011, 09:04 PM | #4 | |
Rep 534
BTW, don't forget to post a pic of your car here http://www.m3post.com/forums/showthread.php?t=530491 ....recognize the red one in the first page? |
06-16-2011, 10:53 PM | #5 | ||
Rep 3,293
Edit: I Can't PM you but I will PM Azorean with my number so you can text me, thanks |
06-16-2011, 11:23 PM | #6 |
Rep 534
06-17-2011, 04:34 AM | #7 |
Grease Monkey
295
Rep 2,646
Drives: 2011 E90 M3,1994 Euro E36 M3/4
The easiest way to install the side gills is to partly remove the fender liners. I stopped trying to pull on mine for fear of breaking something since I was putting a lot of force on them and they were not releasing.
Here is a basic step by step for you: 1) Jack up the car and remove the front wheels (either at the same time or one at a time, your choice) 2) Remove the screws in the fender liners and pull them forward so you can access the back of the gills. (you will have to remove one fastener for the windshield washer bottle on the passenger side, and then pull the bottle toward the front of the car and out of the way. Don't worry you don't have to drain or disconnect it in any way, there is enough slack in the hoses to pull it clear) 3) Reach up and release the clips for the gills and push them out. Once they are out you will have access to the screw which you are asking about and the wire. (This screw only holds the signal light in anyway) 4) Swap the signal light to your new gill, plug in the wire and reinstall it in the fender. 5) Reinstall the windshield washer bottle, fender liners, wheels and lower the car off the jack. Stand back and admire the great job you did! P.S.: I know this sounds like a big deal but is is really only about 1/2 hour worth of work per side. Although you can get them out by pulling or prying I recommend this longer method since it will prevent you from doing any damage to the car/paint/oem gills. |
06-17-2011, 01:50 PM | #8 |
Rep 203
I did it this way. No problems. Requires a fair bit of leverage to pry them off but it took 5 minutes a side.
http://www.youtube.com/watch?v=jHMtTQ50B5g |
06-18-2011, 08:25 PM | #9 | |
Rep 3,293
06-18-2011, 08:26 PM | #10 | |
Rep 3,293
I think I'm just going to sell them and buy a whole set which would be much easier as I would just have to replace the whole thing. *the irony in that |
06-18-2011, 09:13 PM | #11 |
Rep 1,285
Drives: A Car
Just finished doing this very install myself this afternoon. I got stuck at the very same place as you. Unless you can get those tabs out, you won't be able to access the screws. I ended up using a hair dryer, and heating up the part. After about a minute on high heat, the black plastic becomes more pliable, and it becomes much easier to remove the chrome piece after that.
